Big port head flow tuning
04-23-2009, 06:23 PM
Diskovod Wrote:Yeah, man! Thanks for points! When those areas you marked are removed, the term is commonly called "de-shrouding". When removed it is easier to run addition compression, because these high spots get hot, and can cause pre-ignition. The negatives is removing enough, and yet not "hogging" the chamber out... each particle you remove from the chamber DECREASES your compression! It is advised to get the chambers measured accurately *IF* you decide to mess inside the combustion chambers, that way you can make each chamber the same volume, therfore providing equal performance As a comparison to your Atlantic head, here is my street prepared head.... ![]() ![]() I did my chamber work based on the TRD N2 engines (a bit closer to your street performance type) ![]() Oh... you'll need one of these to measure chambers... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-29-2009, 01:01 AM
oldeskewltoy Wrote:Diskovod Wrote:Yeah, man! Thanks for points! ![]() Sure, man! "each particle you remove from the chamber DECREASES your compression!" Yep, I know that, I'm gonna shave the head anyway. Yeah, I'll need to measure them... that's not hard, but it take a little time to make that fluid based measuring stuff ![]() Also I suddenly found through Club4AG your files on the Box with TRD N2 manuals! Thanks for sharing! ![]() I'm going to pull out my engine soon, will be showing pics of progress and be likely to get some more advices. Anyway thanks for your posts! ![]() P.S. Do you know what was the compression ratio for Formula Atlantic? 1972 Ford Taunus (drift project) 1984 Toyota Celica AA63 (4AGE, 5MT, IRS) |
05-04-2009, 07:03 PM
Diskovod Wrote:P.S. Do you know what was the compression ratio for Formula Atlantic? http://www.geocities.com/motorcity/7177/...specs.html - not sure how accurate.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Big wheel problems | gh0st | 16 | 8,937 |
20v mains & big end bearing | izanagi | 9 | 10,791 |
12-26-2016 12:42 PM Last Post: pack |
Small Port Swap | Alex170984 | 1 | 4,355 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,511 |
10-25-2016 09:18 PM Last Post: oldeskewltoy |
Front big brake kit | DidiDex | 14 | 19,423 |
10-24-2016 09:29 AM Last Post: FanIsHere |
