Blacktop header?
04-14-2007, 03:51 PM
Blacktop header?
Hi, i've working on my blacktop project, but has a problem. The original ae86 header dosnt fit my blacktop engine, and the blacktop header will not fit because of the engine mount. What do you other guys with blacktop do? Modyfi the original ae86 header, or buy a new?(Were?)
04-14-2007, 04:00 PM
Blacktop header?
lhd or rhd?
Dan -
04-14-2007, 04:04 PM
Blacktop header?
oldeskewltoy Wrote:lhd or rhd?
Sorry, LHD! Banging head
04-14-2007, 06:42 PM
Blacktop header?
I believe everybody just slots the bolt holes on the ae86 manifold.. a bit of searching around the forum will probably find you some pictures.
04-14-2007, 07:22 PM
Blacktop header?
Ivan141 Wrote:I believe everybody just slots the bolt holes on the ae86 manifold.. a bit of searching around the forum will probably find you some pictures.
Slots the bolt holes? There is a lot of space between the end of the manifold and the bolt hole! Ive been searching alot in the forum for some pics, but didnt found something!
Also the diameter of the holes in the cylinderhead is alot bigger than the header from my stock engine..... :-(
04-14-2007, 08:45 PM
Blacktop header?
Yep,
I have used the pld rwd manifold on my Blacktop,
If you put it on its really easy to see,
You just have to cut open the hole in each end!, then save the part you cut of,
To use with a bigger washer, then it works.
/Skassa
"""www.turbotoys.dk"""
04-15-2007, 04:32 PM
Blacktop header?
Oki thanks Skasssa. What about gasket, did you use the 20v one, or the 16v gasket?
  20v 4age header Alex170984 5 7,888 10-30-2013 12:53 AM
Last Post: fax0815
  Exhaust Header 4AGE Mr2 Only Alex170984 1 3,902 02-07-2013 01:36 PM
Last Post: Alex170984
  Ashley competition header ? Uzelac 6 7,449 06-12-2012 01:42 PM
Last Post: Uzelac
  Header + exhaust for Beams setup KD2229 8 13,093 10-03-2011 07:25 AM
Last Post: KD2229
  New Toda 4-1 longtube header - 98000 yen oldeskewltoy 3 7,672 07-29-2011 08:54 PM
