Bleed nipples
07-24-2009, 06:02 PM
Bleed nipples
I'm having trouble with my brakes, basically brake fluid is seeping from around the bleed nipple thread and tightening up makes little to no difference. Has anyone else experienced this before ?
Thanks, TC
07-24-2009, 08:33 PM
Bleed nipples
Wrong bleed nipple, or some dirt/rust preventing the nipple from sealing against the caliper.
The nipple seals on the conical part at the tip, if there is any contamination there it might cause the problem you're having.
My advice: make sure it's not the caliper first, then get yourself new nipples.. old ones have a nasty habit of breaking.
07-24-2009, 08:54 PM
Bleed nipples
Ivan141 Wrote:Wrong bleed nipple, or some dirt/rust preventing the nipple from sealing against the caliper.
Get yourself all the 4 nipples and replace them all, will need to bleed the brakes two.
[Image: AEU86 AE86 - Bleed nipples]
07-25-2009, 02:08 PM
Bleed nipples
A trip to Mr Toyota on Monday then.
Thankyou all Thumbs up!
  Nipples totta Crolla 7 6,134 04-12-2008 10:33 PM
Last Post: Eric
  How to bleed the Brake Master Cylinder? Rasteirinho 18 13,757 09-27-2007 06:05 AM
Last Post: parrot
  How to bleed brake system after master brake replacement Ivan141 12 19,579 09-18-2005 11:21 PM
