Boro ‘86 Corolla GT
10-01-2016, 02:16 PM
Post: #91
Boro ‘86 Corolla GT
The GL-5 is the correct oil for the diff but you should use GL-4 for the trans. Using GL-5 in the trans will cause synchro problems. Don't ask how I know. If you look in the owners manual it will note GL-4 for transmission. Long term, the EP additives in GL-5 will attack the old type of brass synchro's found in the T-50. Dave W
10-01-2016, 04:17 PM
(This post was last modified: 03-25-2021 05:58 PM by zenki.)
Post: #92
Boro ‘86 Corolla GT
I did use GL-4
ハチロク |
03-25-2021, 06:44 PM
(This post was last modified: 03-02-2022 12:36 AM by zenki.)
Post: #93
Boro ‘86 Corolla GT
Last post 2016^^
Since tinypic died all the pictures are gone but shit from the past, not going to bother reupping them. Current situation. I've used the car as my daily for years just maintaining it mechanically. I had a vision in my head on how i wanted to build my ae86 but somewhere, sometime i went off track. (like buying rotas) Reflecting on that, it isn't what i wanted and decided i needed to take a different approach. Which is taking things slower, save money, put in the work. I'll make a few posts with everything i've done so far. ハチロク |
03-25-2021, 08:59 PM
(This post was last modified: 08-16-2021 02:33 PM by zenki.)
Post: #94
Boro ‘86 Corolla GT
I'll be posting everything in no particular order. (2017 till now)
Put on a new apexi air intake. Fitted a group A header and street exhaust system from Martelius. New brake calipers front & rear, pads & discs, handbrake cables. Put on new inner & outer tie rods, dustboots, lower control arms & powersteering knuckles on manual rack. Changed the blown tokico blues to bilsteins with new topmounts. ハチロク |
03-25-2021, 10:16 PM
(This post was last modified: 03-02-2022 12:41 AM by zenki.)
Post: #95
Boro ‘86 Corolla GT
Polybushed the whole car.
Axle rebuild with cusco rs lsd, oem 4,6 r&p and new bearings/gaskets. Genuine Noby Booth wing. ハチロク |
03-27-2021, 10:36 PM
Post: #96
Boro ‘86 Corolla GT
Nice! I love that wing!
User(s) browsing this thread: 18 Guest(s)
