Valve clerance for 4age 16v
01-23-2007, 09:47 PM
Hi guys im looking to do a shimless conversion from 1SZFE to my 4age 16v red-top engine. Since the under-bucket shims is crazy expensive ill go for 1SZFE conversion.
I will use 272deg 9mm camshaft(int\ext) and im looking for valve clerance to use these camshafts.
I have a Toyota repair manual and it say the valve clerance should be:
Intake: 0.006in to 0.010in
Exhaust: 0.008in to 0.012in
But these clerance are for stock camshaft.
I got also a TRD Bible wich set the clerance for a 272deg 7.5mm lift to:
Intake: 0.005in
Exhaust: 0.007in
But i want to be sure of wich clerance I can use for my type of camshaft, someone know a clerance to be used for a 272deg 9mm lift camshaft(int\ext)?
Thank a lot
Ugo
01-23-2007, 10:07 PM
you 'll have to find the installation sheet of your cams my friend ...
01-23-2007, 10:56 PM
only know is that they should be less than the 7.5 lift, but you probably knew that already
hope you find the right info Smile
01-24-2007, 12:00 AM
delange thats not true, I had 8.5mm lift on my exhaust cam and 9 mm lift on my intake.
http://www.catcams.be/800x600/prod01Alis...71051xx.js
I had teh second one. (have them now ones more) They can be fitted and work fine!
valve info!
http://www.catcams.be/datafiles/docs/spr...051xx1.htm
01-24-2007, 12:14 PM
robokill Wrote:delange thats not true, I had 8.5mm lift on my exhaust cam and 9 mm lift on my intake.
valve info!
I ment that the clearence schould be less, cause of the higher lift, correct me when I'm wrong Smile
01-24-2007, 10:27 PM
I have look carefully in the box, no paper at all about valve clerance.
These cams are Toda racing 272deg 9mm lift.
If i cant find the right valve clerance specs i think i will go for the N2 valves clerances specs and see what happen.
01-30-2007, 08:51 PM
On my Web cams(294 grind)... I'm using stock specs...
cold
intake - .15mm to .25mm
exhast - .20mm to .30mm
I'm the overzealous type... so I made ALL intake clearances .2mm and all exhaust .25mm each is dead on in the middle of the spec
by matching all clearances..... in theory... all lifts/durations will then be identical when measured at the valve
Dan -
01-30-2007, 10:42 PM
Clearances are related to the material which the cam is made and not its lift or duration.
HKS states that for 256/264/272 camshafts the clearances are the following:
Intake 0.25mm +/- 0.03mm
Exhaust 0.30mm +/- 0.03mm
Toyota states something different that I can't find right now!
Best regards
  4AGE Valve Buckets Scored Steller Engineering 2 1,078 10-06-2023 05:34 PM
Last Post: Steller Engineering
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,678 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,522 05-25-2022 10:24 PM
Last Post: oldeskewltoy
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 21,825 05-01-2021 10:09 PM
  4AGE 16V engine overheat when at high speed chenfon 32 23,958 12-31-2020 06:39 AM
Last Post: chenfon
