Broken lsd?
10-22-2005, 07:25 PM
Broken lsd?
hey banpei you got a set of links ????
10-22-2005, 08:01 PM
Broken lsd?
I see similar damage when some stupid drivers use jack on these links to lift the car....
10-22-2005, 08:19 PM
Broken lsd?
jamiemirror Wrote:I see similar damage when some stupid drivers use jack on these links to lift the car.... YES!!! When i bought my car one of the lower rear links was suspiciously bent upwards?? at closer inspection it was obvious a jack was tucked under at some stage and the gobshite jacked the car up by it!! luckily it was a crappy std item and i was changing anyway...some people are dopey when it comes to basic common knowledge a small bit of cop on?? ![]() At last Itsuki is gone.....:o) Who the hell is Itekani?? lol...Wataru! ???? |
10-22-2005, 09:35 PM
Broken lsd?
robokill Wrote:hey banpei you got a set of links ????Yeah, that was one of the reasons for going to TE71Corolla: he promised me a set of stock links when I bought the car and as part of the deal with the breaklines swap was he would swap the links as well. ![]() jamiemirror Wrote:I see similar damage when some stupid drivers use jack on these links to lift the car....Auch, but then they would use the jack under the horizontal link. The ones that broke were the diagonal links. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
10-23-2005, 05:19 AM
Broken lsd?
[/quote]
Auch, but then they would use the jack under the horizontal link. The ones that broke were the diagonal links.[/quote] Diagnol links!! u mean upper links or lower links?? the lower links are the long ones...which are the ones that dummys generally jack a car up on and the uppoer links are the shorter smaller limnks on the centre. how wud u consider them diagnal? either way the upper links and all 4 links are very important in their own right...if 1 goes they can all go as they act in unison. very gud mods on the rear suspension for driver feel and less floaty rear end like the panhard rod. arbs are the ultimate like largus for drifters anyway... ![]() At last Itsuki is gone.....:o) Who the hell is Itekani?? lol...Wataru! ???? |
10-23-2005, 08:46 AM
Broken lsd?
banpei Wrote:jamiemirror Wrote:I see similar damage when some stupid drivers use jack on these links to lift the car....Auch, but then they would use the jack under the horizontal link. The ones that broke were the diagonal links. Yeah - I see that they are short ones. I just share some "non desired expirience". |
10-23-2005, 10:47 AM
Broken lsd?
Ian - AE86 Wrote:Diagnol links!! u mean upper links or lower links?? the lower links are the long ones...which are the ones that dummys generally jack a car up on and the uppoer links are the shorter smaller limnks on the centre. how wud u consider them diagnal? either way the upper links and all 4 links are very important in their own right...if 1 goes they can all go as they act in unison. very gud mods on the rear suspension for driver feel and less floaty rear end like the panhard rod. arbs are the ultimate like largus for drifters anyway...The lower links are 100% horizontal, the upper (and shorter) links are not 100% horizontal, so that's why I said diagonal. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Broken 20v upper timing belt cover | chip | 2 | 4,312 |
07-16-2012 07:11 AM Last Post: Jan Pedersen |
Broken bolts - Water pump | pack | 13 | 13,946 |
10-05-2011 08:02 PM Last Post: pack |
changing diff ratio, broken LSD??? | fax0815 | 6 | 7,824 |
09-06-2011 08:19 PM Last Post: fax0815 |
my last broken engine....(probably not least) | filh | 9 | 7,463 |
04-09-2009 10:50 PM Last Post: Rasteirinho |
Broken rear end(ring pinion) | filh | 9 | 8,269 |
09-11-2008 11:06 PM Last Post: filh |
