Built like an A-10 (Thunderbolt II aka Warthog)
06-02-2011, 02:48 AM
Petros AE86 Wrote:congrats mate..what mods you need to fit beams inside?you put it alone?what about ecu etc?
Mods to the chassis? None.
I was able to squeeze it in with custom engine/trans mount brackets and ZERO modifications to the chassis/engine crossmember/etc.
Andrew
06-02-2011, 03:18 AM
GOod stuff..
06-02-2011, 03:19 AM
Nice and quick work!
How is the ViPEC, looks good & does it costly?
You have std internal of your motor?
06-02-2011, 03:20 AM
06-02-2011, 04:41 AM
The Vi-PEC is around $1700 USD at this time IIRC. Motor is completely stock standard, except for the ITB's and manifold back exhaust.
Andrew
06-02-2011, 08:10 AM
You know if they do a basic mapping for particular setup?
If dyno is not propular in my place.
06-02-2011, 11:50 PM
I'm sure they can come up with a basemap.
Andrew
06-06-2011, 08:29 PM
very cool setup! what bellhousing did you use for the swap?
06-14-2011, 06:19 AM
Nice job man.
Is that hp rating at the wheels or flywheel?
06-15-2011, 07:16 AM
daytona350z - modified tarago/hiace bell.
Hachi Go - Thanks, that's at the wheel.
Andrew
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,371 10-28-2022 08:23 AM
Last Post: decryphe
  ae86 Trueno f20c Built to be driven not polished Martynas 45 55,726 05-29-2020 12:59 PM
Last Post: decryphe
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 43,464 07-22-2019 02:55 PM
Last Post: apardal
  ae86 3sge beams turbo built v mount intercooler boryae86 9 23,143 10-25-2010 02:46 PM
Last Post: boryae86
