Bushings!:)
04-19-2005, 09:08 PM
Bushings!:)
original bushing
![]() t3 delrin bushing ![]() t3 delrin bushing in place ![]() T3 camber plates ![]() engine bay ![]() camber! ok, this doesn´t show well....-1,7degrees (damn, with standard spring plates, it doesn´t allow more, the plate hit the chassis tower from inside ![]() ![]() t3 rca´s & prothane bushings ![]() a job well done, now, i´m one official owner of a street kart Did any of u notest the big increase in vibrations and noise after the poly bushings being installed? |
04-19-2005, 11:32 PM
Bushings!:)
[quote="Tofu @ AE86"]
T3 camber plates ![]() Tofu..... when fitting the T3 CP´s... how did you do with the fact that the fron springs are way to large to fit the CP´s... do you perhaps have any pics from below 6 with the entire front shock assembly laying beside the car ? K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
04-20-2005, 12:29 AM
Bushings!:)
err...no, i didn´t take any photos with the strut assembly out....but....does any body got the same problem?
because, i´m sure that with coilovers, that shouldn´t have any problem since the upper hat diameter is way smaller that the stock one... ![]() well....i need to investigate a little... |
04-20-2005, 11:41 PM
Bushings!:)
Kristian, if you're not using coilovers it shouldn't be a problem because you just remove the top mount and leave the stock upper hat that receive the spring...
04-21-2005, 09:53 AM
Bushings!:)
2 tofu: you don't need RCA's when runing stock height. In fact you upset car's rollcenter. They are used to correct angle on lowered cars only.
04-21-2005, 10:34 AM
Bushings!:)
apardal Wrote:Kristian, if you're not using coilovers it shouldn't be a problem because you just remove the top mount and leave the stock upper hat that receive the spring... thats the problem. I´ll have totake the stock upper hat apart in ordet to fit it together with the CP. strange, but true. K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
04-21-2005, 03:57 PM
Bushings!:)
errr...the car is lowered 30mm with sparco springs
04-21-2005, 04:34 PM
Bushings!:)
Tofu @ AE86 Wrote:errr...the car is lowered 30mm with sparco springs Um....well then ok. Stil rca's are most used on extremly lowered ae86. :wink: Pitty you don't have coilovers yet. Drifting - best fun you can have in your car with your pants on! |
06-06-2005, 02:21 PM
Bushings!:)
New problem with fitting bushings for rear swaybar !.
i just took the swaybar off the car. but the new bushings are WAAAy to big - it says 22mm on the package. but my swaybar is at the most 17-18mm And it id NOT rusted on the fittingpoint It will never fit se picture. have all you guys recived the same package as me ? I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
06-06-2005, 02:26 PM
Bushings!:)
KristianAE86, that is for the front. As far as i remember there are two types of front swaybars, one 21mm and one 22mm therefor double sets. What you want is this one;
Poly vs OEM bushings | Jezza_hr | 5 | 7,775 |
05-14-2014 11:28 PM Last Post: Jezza_hr |
Steering Rack bushings | filh | 4 | 6,125 |
03-12-2010 10:45 PM Last Post: filh |
Drivers review Prothane Bushings | Michel | 11 | 17,388 |
04-13-2008 05:57 PM Last Post: Mux213 |
Witch one to buy?(Bushings) | zounds | 3 | 5,057 |
11-23-2006 12:03 AM Last Post: delange |
Bushings question. | CircuitFreak | 18 | 17,474 |
06-20-2006 03:02 PM Last Post: Ivan141 |
