CR bluetop EU
06-22-2006, 10:45 AM
CR bluetop EU
Yo! Sounds silly but the question is:
What is the compression ratio of the european bluetops without catalytic convertor? I ask this, because I saw in some more european magazines CRs of 10:1. Which is maybe a mistake I tought, but an owner of the manual of the car in Germany is confirming that it is 10:1 for the EU models without catalytic convertor in his manual(the book from 1984). These are the facts so far: ![]() and this http://www.stud.uni-karlsruhe.de/~urmj/A...03-big.jpg and this: http://www.stud.uni-karlsruhe.de/~urmj/A...03-big.jpg against this: http://club4ag.com/faq%20and%20tech_page...ations.htm So... could you also provide arguments for your choice when voting? "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
06-22-2006, 11:48 AM
CR bluetop EU
That’s a good question, Portuguese AE86 don't have catalytic converter, and "Salvador Caetano" ( Portuguese Toyota importer) always said that it has 10:1 compression, but I have some doubt's about that.
I can tell you that for the blue top (18mm pin piston) there are 2 different part numbers for pistons in Toyota, and one is taller than the other, but in the end I can't confirm anything for sure, so I won't vote. But that is a really good question. |
06-22-2006, 12:53 PM
CR bluetop EU
Its 10,0:1 with octane 98
I got that directly from the datasheet from Toyota. Youtube Myspace and I´ll Google your Yahoo |
06-22-2006, 01:21 PM
CR bluetop EU
My Bluetop without catalytic convertor in AE82 has 9.4:1 ... that's for sure...
![]() Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
06-22-2006, 01:25 PM
CR bluetop EU
Well, that could explain the 121hp in AE82 and the 124 in AE86.
I got the complete datasheet specific to my car, and it says 10:1. Youtube Myspace and I´ll Google your Yahoo |
CR bluetop EU
meshin Wrote:My Bluetop without catalytic convertor in AE82 has 9.4:1 ... that's for sure... Did you measure it? ![]() Btw. a way to calculate it is, by having the volume of the combustion chamber. Then we know the bore & stroke. Just dont know the volume ![]() Knudsen - 3 HP difference can be from the ECU too. "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
06-22-2006, 01:39 PM
CR bluetop EU
Yes, the documents from the finnish Toyota importer Korpivaara (back in the 80s) also state that the AE86 engine compression ratio is 10.0:1. At least the US models seem to use 9.4:1, on the other hand.
The primary difference seems to be the pistons - 10.0:1 models have a small dome on the middle of the piston which decreases the combustion chamber volume by about 1.6cc when compared to a completely flat piston. The 9.4:1 model, on the other hand, has a very similiarly shaped dish in the middle of the piston. It increases the combustion chamber volume by 1.6cc when compared to a flat piston, and 3.2cc when compared to the domed piston. Note that I calculated these dome/dish volumes by assuming 39cc as the head combustion chamber volume and a 1.2mm compressed head gasket thickness. |
06-22-2006, 02:32 PM
CR bluetop EU
I have seen in some brochure that:
AE86 have 11:1 and other tells 10:1 AE92 have 10:1 AW11 have 10:1 |
06-22-2006, 05:13 PM
CR bluetop EU
El_Camino Wrote:Knudsen - 3 HP difference can be from the ECU too. I can only speak for the danish models, and they have all the same type ECU´s. Youtube Myspace and I´ll Google your Yahoo |
06-23-2006, 08:32 AM
CR bluetop EU
Looks like the 9,4 is a BIG myth ... at least no facts are speaking for it so far
![]() "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 11,089 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 12,916 |
Bluetop on turbo | leon205gti | 7 | 8,623 |
09-20-2016 09:17 PM Last Post: leon205gti |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 38,569 |
08-21-2016 04:51 PM Last Post: ray |
Bluetop AFM with air filter | izanagi | 4 | 7,606 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
