CR bluetop EU
06-26-2006, 01:13 PM
Post: #31
CR bluetop EU
I also checked the pistons, suitable for my car:
STANDARD: 13101-16020 : piston sub assy w/pin models: 4agec, 4age... ae86... GEN, ME, SDZ, FRG O/S 0.50: 13103-16020: piston sub assy w/pin models 4agec, 4age... ae86... GEN, ME, SDZ, FRG I also entered another VIN (Knudsen's car), and I've got DIFFERENT piston part numbers !!! STANDARD: 13101-16030: piston sub assy w/pin models: 4age...ae86...EUG O/S 0.50: 13103-16030: piston sub assy w/pin models: 4age...ae86...EUG So there are really two or more different pistons used in bluetop 4age. I'm wondering, when doing a rebuilt, if I can use the ones for more compression (EUG market ones: 13101-16030 or 13103-16030) in my 4age and so acheive more power Regards Andrej |
06-26-2006, 01:16 PM
Post: #32
CR bluetop EU
Quote:I'm wondering, when doing a rebuilt, if I can use the ones for more compression (EUG market ones: 13101-16030 or 13103-16030) in my 4age and so acheive more power...or more service history :-) Make a dry build. You shoul have at least 1mm clearance in piston's valve pockets - with valves full pressed. |
06-26-2006, 01:31 PM
Post: #33
CR bluetop EU
What does it mean to make a dry build ? To build the engine and to mesure the clearance before starting the engine ?
There's another way, I can check other part numbers, like valves, valve springs, cammes, etc. if they are the same in 4age (EUG market) and 4agec (SDZ market)... Regards Andrej |
06-26-2006, 01:35 PM
Post: #34
CR bluetop EU
2 Bad Dog: Red Top has 10.3:1 CR, so it's not a big difference from 10:1 CR of AE86 Bluetop...
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
06-26-2006, 03:45 PM
Post: #35
CR bluetop EU
dreja Wrote:What does it mean to make a dry build ? To build the engine and to mesure the clearance before starting the engine ? http://www.guy-croft.com/page12.html (if you cannot open this, just read that description: Quote:Put the head dowels in place and use a gasket of one type or another, this is the colourful beauty from the latest Federal Mogul Payen set - which is massively better than the ones they supplied a few years ago. If you don’t use the dowels the results will be completely meaningless. I use Plasticine (modeling clay) in the valve cutouts (reliefs) to check the vertical and radial clearance. It is necessary to grease the valves or they will simply pick up the clay when u turn the engine over. This particular engine had 3A cams (it is Ben Ellis’s 2 liter Spider) and u can see that the valves don’t stick out that much at tdc, however closest proximity with some cams is NOT tdc but might be anywhere between 15-20 deg after tdc on the inlet, (cannot remember on the exhaust) as the valve is opening faster than the piston moves away.) |
06-27-2006, 09:39 AM
Post: #36
CR bluetop EU
I have driven my old 84' coupe with MAP and 124HP and now i am running on 85' AFM coupe. Those cars are totally different i was feeling that the MAP version was a lot powerfull than this AFM. Maybe there is the most difference in engine compression ?
85' AE86 GT coupe lifetime project since 2005 |
06-27-2006, 01:08 PM
Post: #37
CR bluetop EU | |||
06-28-2006, 11:52 AM
Post: #38
CR bluetop EU
Already read that faq on club4AG but it helps me no further still is the question why are this cars so different nobody has idea that i asked i think the only possible way to discover what can be it is to get the engine from the old rusty hachi to this coupe with all the cables and ECU.
And if it has no gain in power try also to replace tranny. But i dont think there was some work around the tranny. 85' AE86 GT coupe lifetime project since 2005 |
06-28-2006, 12:07 PM
Post: #39
CR bluetop EU
Ryo, as I found the different part numbers for pistons, there might be the answer...
All other things (as piston rings, valves, valve springs and stems, etc. ) seem to be the same part numbers for may Swiss AFM version and for GEN map version... So there's the possibility that if you put the pistons inside (13101-16030 / 13103-16030) instead of 13101-16020 / 13103-16020, you wil have more power. BTW. Ryo do you have a red sticker showing engine vacuum connections under the hood ? Does it say Swiss 4agec on the sticker ? Regards Andrej Regards Andrej |
06-29-2006, 01:17 PM
Post: #40
CR bluetop EU
Yup look... the sticker is blue and say's 4A-GEC USA&CANADA
http://fotky.azet.sk/jsAlbum.phtml?i9=aa...&al=947473 85' AE86 GT coupe lifetime project since 2005 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 9,116 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,898 |
Bluetop on turbo | leon205gti | 7 | 7,810 |
09-20-2016 09:17 PM Last Post: leon205gti |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 33,210 |
08-21-2016 04:51 PM Last Post: ray |
Bluetop AFM with air filter | izanagi | 4 | 6,956 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
