Cam timing help
12-29-2007, 06:28 AM
Cam timing help
ok so i picked up a nice set of HKS 304/304 8.35mm lift cams. so i was reading bill sheerwoods page on cams, and he says that that size of cam should have a lobe center of around 100-100.
then goes onto explain that if i were to rotate the motor 100 degree clockwise i should see the intake cam be fully opened up. same for exhuast 100 degree counter clockwise exhuast be opened.
alright so lets say i do that and my intake isnt fully open. would i then just go back to TDC and then adjust the cam gear a bit(i have fully adjustable gears) and then again rotate 100 degree and see?
or is it harder then what it seems?
12-31-2007, 08:17 AM
Cam timing help
YES Smile Or when you are at 100 degrees, adjust the camshaft to obtain
maximum lift (the result is the same). Keep in mind that the camshaft
will have several degrees of "dwell" at maximum lift (the camshaft will
rotate with no change in lift). Try and put the lobe in the centre of this
no more lift angle of rotation.
There is a more accurate method of setting the cam separation, which
involves finding the point of 0.050" opening on each flank, and dividing
by two to obtain the centreline. But if you are planning to play around
with lobe separation, your method will be fine Smile
Cheers... jondee86
01-03-2008, 10:08 AM
Cam timing help
Only mildly off-topic Smile
Does anyone know the lobe separation for the standard OEM cams
in the late AE92 "smallport" 16V 4AGE ?? All I can find by searching
is that it will be somewhere between 100-100 and 110-110 Confused
I have adjustable pulleys without any markings, and I would like to
be able to degree the cams to obtain the correct factory timing as a
baseline. Then when I install my new cams I can degree them to the
same settings to obtain a performance comparison.
Cheers... jondee86
01-04-2008, 10:42 PM
Cam timing help
On Club4AGE there is a listing of 111-111 for stock cams on the
cam comparison page. But then there is a rather contradictory
statement about finding good power at 100-100 Huh
So if anyone has experimented with lobe separations on their OEM
cams, I would like to know what settins you have used.
Cheers.... jondee86
05-22-2009, 05:46 PM
Cam timing help
Hi Jon,
did you ever find out any more info on this? I have the belt off my car at the moment to do some work, and was going to throw my Toda pullies on - just wondering if you found any info on cam timing settings on the stock engne / cams?
Cheers
James
[Image: AEU86 AE86 - Cam timing help]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
05-23-2009, 06:25 PM
Cam timing help
Far left is std.
Dan -
05-24-2009, 12:59 AM
Cam timing help
Good stuff Oldeskewl Smile
I had a bit of a struggle to read the numbers, so I have reposted
your info with my best guess figures shown below the std cam. Feel
free to correct anything I have figured wrong.
And since the numbers give 232 duration, they are the smallport
numbers I was looking for. Now I have some work to do Smile
Cheers... jondee86
[img name=]http://www.aeu86.org/files/bi/biblecaminfo01_179.jpg[/img]
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,156 07-18-2019 03:52 PM
  Cam Cap Bolt Snapped!! Alex170984 1 3,901 06-08-2018 01:17 PM
  HKS 260 8.0 Cam Card d3nso 5 7,289 02-14-2018 08:29 PM
  4agze timing leon205gti 11 14,173 04-07-2017 03:10 AM
Last Post: jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,422 11-05-2016 01:34 AM
