Camber Plate
04-19-2010, 08:53 AM
Camber Plate
Whatever is cheapest, its not like they are high tech. Even the Cusco's will be more then fine if you clean it up a bit and relube everything.
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 57,850 11-18-2022 02:19 PM
Last Post: FanIsHere
  What is normal and low caster in Cusco camber plates?? T_AE86 9 15,654 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Camber adjustment vs original struts Lt86 9 9,830 05-07-2015 09:45 PM
Last Post: zenki
  Spindle dimensions, backing plate bolt pattern Rascal21 18 22,463 03-13-2014 11:45 AM
Last Post: Rascal21
  back camber of CBY roiz86 5 9,073 03-24-2013 02:00 PM
Last Post: roiz86
