Cams for a stock 4age 16v
02-19-2009, 10:13 AM
Post: #71
**COROLLA EE80 - 4AGE 124HP** ![]() |
02-19-2009, 06:42 PM
Post: #72
tolisspi Wrote:the hks cards is better than toda Thank you for this information! This is what I have for Toda.... It appears to be a match for your first page, but in English ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-20-2009, 09:18 AM
Post: #73
But TODA doesnt give the lift (in the 1st page) and the revs , only the CR
Thx me too, because i dont know very well the japanese ![]() **COROLLA EE80 - 4AGE 124HP** ![]() |
06-10-2009, 10:19 PM
Post: #74
Dont know a lot about cams..So here's my question:
Do the intake and exhaust cam have to be indentical? And preferably of the same brand? Also, will this be a good intake cam for a stock 4age: 258° peak timing: 110° cam lift: 8mm valve lift at TDC: 1,1mm valve clearance: 0,25mm I hope I all translated this right.. Atleast the figures are right, so I think the pro's can see what kind of cam this is ![]() |
06-11-2009, 07:13 PM
Post: #75
dipends, but if you read the maps in the other posts, you can see that they have to be differents and not identical. But i think that be adjusting with the adjustable cam gears (im not sure).
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,537 |
82mm Stock compression Pistons | apardal | 4 | 2,968 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 21,326 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 22,536 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,684 |
