Camshaft ID
09-24-2018, 10:48 PM (This post was last modified: 09-24-2018 10:49 PM by kazi.)
Camshaft ID
Anyone have any ideas on what camshafts these are and what size? They are stamped JD and on the end stamped (what looks like) TRKI and then 1006
[Image: AEU86 AE86 - Camshaft ID]Untitled by ae86-kazi, on Flickr
09-25-2018, 07:35 AM
Camshaft ID
Don't know anything specific, but they look like they have pretty decent
duration and maybe 10mm lift. You might have to get them clocked by a
cam maker to get the full specs.
Cheers... jondee86
09-25-2018, 12:16 PM
Camshaft ID
9.5mm lift is right at the maximum lift before the lobe hits the head casting. My guess would be 8.8mm lift and 288° duration.
09-25-2018, 08:33 PM
Camshaft ID
(09-25-2018 12:16 PM)totta Crolla Wrote:  9.5mm lift is right at the maximum lift before the lobe hits the head casting. My guess would be 8.8mm lift and 288° duration.
Head has some work done to it they might be 10mm lift. These where fitted to a lotus sunbeam rally car and they normally do pretty out standing head work in the rally community around here so the castings might have been shaved away.
09-25-2018, 09:23 PM
Camshaft ID
Judging by your pictures ther was no work done around the lifter so less than 10mm
Sent from my MHA-L29 using Tapatalk
09-25-2018, 11:25 PM (This post was last modified: 09-26-2018 12:15 AM by jondee86.)
Camshaft ID
If you can get at the cams with a caliper, measure twice (base circle
and then lobe to back of cam) and the lift will be the difference.
According to Oldeskewltoy, this...
... is a 297 (advertised) duration 10.410mm lift intake cam which needed
a fair bit of grinding on the head to get clearance for the cam.
This one is 300 (advertised) duration x 8.6mm lift...
.. and looks a bit more like yours.
Cheers... jondee86
09-26-2018, 12:07 AM
Camshaft ID
This is what they mean by work around the lifter bucket it allows the cam to rotate.
OP's cam is a pretty long duration cam (rounded nose...) and it appears to be less than 10mm.
The cam in the photo below is 9.4mm.
Dan -
  Question about camshaft CHACAMAN 2 3,828 07-07-2020 06:41 PM
  Anyone farmiliar with hks camshaft types for 4age? spill86 5 16,604 11-18-2017 11:36 PM
  Camshaft sprocket bolt size? harkes 1 4,771 07-03-2015 12:41 PM
Last Post: Dave W
  Camshaft questions d3nso 7 8,312 08-16-2013 11:19 PM
Last Post: jondee86
  What camshaft Anonymous 9 9,796 09-01-2010 10:51 PM
