Camshaft ID
09-24-2018, 10:48 PM
(This post was last modified: 09-24-2018 10:49 PM by kazi.)
Camshaft ID | |||
09-25-2018, 07:35 AM
Camshaft ID
Don't know anything specific, but they look like they have pretty decent
duration and maybe 10mm lift. You might have to get them clocked by a cam maker to get the full specs. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
09-25-2018, 12:16 PM
Camshaft ID
9.5mm lift is right at the maximum lift before the lobe hits the head casting. My guess would be 8.8mm lift and 288° duration.
09-25-2018, 08:33 PM
Camshaft ID
(09-25-2018 12:16 PM)totta Crolla Wrote: 9.5mm lift is right at the maximum lift before the lobe hits the head casting. My guess would be 8.8mm lift and 288° duration. Head has some work done to it they might be 10mm lift. These where fitted to a lotus sunbeam rally car and they normally do pretty out standing head work in the rally community around here so the castings might have been shaved away. |
09-25-2018, 09:23 PM
Camshaft ID
Judging by your pictures ther was no work done around the lifter so less than 10mm
Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
09-25-2018, 11:25 PM
(This post was last modified: 09-26-2018 12:15 AM by jondee86.)
Camshaft ID
If you can get at the cams with a caliper, measure twice (base circle
and then lobe to back of cam) and the lift will be the difference. According to Oldeskewltoy, this... ... is a 297 (advertised) duration 10.410mm lift intake cam which needed a fair bit of grinding on the head to get clearance for the cam. This one is 300 (advertised) duration x 8.6mm lift... .. and looks a bit more like yours. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
09-26-2018, 12:07 AM
Camshaft ID
This is what they mean by work around the lifter bucket it allows the cam to rotate.
OP's cam is a pretty long duration cam (rounded nose...) and it appears to be less than 10mm. The cam in the photo below is 9.4mm. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Question about camshaft | CHACAMAN | 2 | 3,609 |
07-07-2020 06:41 PM Last Post: oldeskewltoy |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 15,775 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
Camshaft sprocket bolt size? | harkes | 1 | 4,611 |
07-03-2015 12:41 PM Last Post: Dave W |
Camshaft questions | d3nso | 7 | 7,998 |
08-16-2013 11:19 PM Last Post: jondee86 |
What camshaft | Anonymous | 9 | 9,435 |
09-01-2010 10:51 PM Last Post: banpei |
