Can't fire up. Buzzing from the relay, lamps blinkin- HELP
01-15-2007, 01:09 AM
Post: #51
Problem solved, electrical at least.
It was ECU ground, it wasn't connected properly. The relay buzing was EFI main relay 2 (in manual nowhere mentioned where is it located). Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
01-15-2007, 05:46 PM
Post: #52
They tricked me into the McDonalds.... I didn't want to leave the house... I was so depressed and mad because of all the things with the car and all...
My girlfrend said that we must return the wheel to Meshin that he lend us when she busted her tire on the Starlet... So I went... As we arrived the McD I saw Zax's 200SX and I knew something was fishy... The present was a new cell phone!!! (realy needed that... mine is dying for some time now...) Rio brought me some lighter fluid and matches... (although it apears I don't need it.. :wink: ) Zax brought a big Milka chocholate (oooohhh I neede that!! diet is for metrosexuals...) Meshin brought the wire harnes for AE86 and a 30A fuse that we blown .... The best present were them selfs... THANX GUYS... You made me change the view on life and current situation... Right now I am on coledge. In about an hour or so, I am going home, going to put some gas in the tank (just to be sure...),, pick up the battery from the charger at Perhan's, put all together, cross my self, pray and hope IT will fire... If it does... I have to make the aluminium hose (between the thermostat and the part above it because that little hose is ruined at the edges, I can't put the O ring rubber and seal the coolant from spilling out...) Mount some used tires on the tele rings, change those winter wheels for the telephone ones... Check the oil and it's track day saturday!!! WEEEEEE... SNO-MO-BIRU project started- CHIRO |
01-15-2007, 06:30 PM
Post: #53
Good luck!
01-16-2007, 03:03 PM
Post: #54
IT'S ALIIVVEEEEEE!!!!!
IT fired today... i emptyed the battery trying to fire, and then it hit me... I took the batery from the starlet, put it on, and my girlfriend sat in the car and started crancking... turned the distributor way too much and it started giving life signals... took the distributor of, turned the mark of the distributor slightly clockwise... less timing, put the distributor back in and BANG! like a song to my ears... It seems when puting the distributor, the marks should be slightly clockwise off not on the mark... mine was on ther mark and in but as the gears are curved it would turn of the mark when pushed in... or wouldnt catch the gear it should... So the rotor slightly less timing (clockwise) and in... If it is not a problem, admins and mods, please copy/ paste this whole topic into this one: http://www.aeu86.org/viewtopic/ae86/t/3737/start=75 to keep the original topic up to date... (the reason why I put this topic for it self at the start was to make more people see it, and now we have a good know how... ) Thank you.... SNO-MO-BIRU project started- CHIRO |
01-16-2007, 06:32 PM
Post: #55
Congratulations!
But the whole topic? Uhm, better (=less work) refer from you original topic. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-19-2007, 01:32 PM
Post: #56
okaj... done...
Had trouble with that small aluminium hose that goes from the water pump to the uper thingy on the head from wich a hose goes to the radiator... It was busted so I did a new one... Leaking at first, so I was checking coolant every few minutes... Sealed it now... Also, yesterday I have put the Sparco seat in the car... a whole diferent story... For now everything is ayokay... SNO-MO-BIRU project started- CHIRO |
01-19-2007, 01:38 PM
Post: #57
Whow!!!
Nice to hear its finally running!!! Good job! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
01-19-2007, 02:07 PM
Post: #58
yep... wnesday fired up, yesterday sealed everything, put the seat in and saturday it's track day... I hope it will live...
01-19-2007, 04:46 PM
Post: #59
man dont you think youre pushing your luck with a track day? i know i wont go racing until my car si 100% ready, it would be a shame to blow something now that you've fixed it.
01-21-2007, 03:21 PM
Post: #60
The car was running perfect on Track day...
Mrgud gaved everything he got, and results were really god, remembering the car is all stock.. And my little can trying hard Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,130 |
03-05-2023 09:34 PM Last Post: Ivan141 |
Can you convert your 86 back too the original state? | gh0st | 7 | 2,698 |
04-25-2022 04:25 PM Last Post: gh0st |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 7,679 |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 10,280 |
09-08-2021 12:48 PM Last Post: Ryo |
can i just slam a oem turbo on it ? | MC_JP | 3 | 5,948 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
