Can you seperate trueno kouki bumper lights into zenki bumper lights?
10-08-2021, 11:58 AM
Hey everyone,
I can't find any zenki trueno bumper lights for my Levin to trueno conversion project. However after taking a closer look at the kouki bumper lights of the trueno, it could be very well possible to take them apart.
To make my explanation a little easier, I have added pictures.
[Image: AEU86 AE86 - Can you seperate trueno kou...er lights?]
Could this be done?
- Gh0st
10-08-2021, 01:36 PM
I wouldn' t abuse kouki lights to do this.. perhaps AW11 MR2 ones are more similar?
10-08-2021, 01:53 PM (This post was last modified: 10-08-2021 01:54 PM by pack.)
It's not possible.
You should really follow the MR2 AW11 approach. Direct fit (kinda).
10-08-2021, 02:57 PM
(10-08-2021 01:53 PM)pack Wrote:  It's not possible.
Thanks guys, this helps out a lot!
I just have question, suppose I fit the MR2 AW11 lights in the zenki bumper, what do you mean exactly with "It kinda fits", will it fall out during driving?
10-08-2021, 04:39 PM
I am not sure if the bumper fixing holes are exactly the same.... that's why i'm saying that.... apparently some people have used it... so it should work Smile
10-08-2021, 09:24 PM
The kouki indicators are bigger (higher) than the zenki indicators, so they simply won't fit.
Like Pack says, the glass of the MR2 indicators is the same shape/size and fitting holes are also at the same spot. I replaced the glass of my JDM Trueno with the ones from the MR2 to make them legal in NL. So I'd think they should fit the bumper with the same mountings.
10-09-2021, 07:49 PM
Contact jesse streeter, he’ll find them for you.
ハチロク
10-12-2021, 06:27 PM (This post was last modified: 10-12-2021 06:28 PM by gh0st.)
(10-08-2021 09:24 PM)banpei Wrote:  The kouki indicators are bigger (higher) than the zenki indicators, so they simply won't fit.
Thanks, that helps out a lot
(10-09-2021 07:49 PM)zenki Wrote:  Contact jesse streeter, he’ll find them for you.
If he's able to find the MR2 bumper-lights, that'd be great. I can't find them anywhere
10-12-2021, 08:20 PM (This post was last modified: 10-12-2021 08:24 PM by banpei.)
I found a left indicator for sale on Ebay:
https://www.ebay.co.uk/itm/255162444287
You can try this Marktplaats seller:
https://www.marktplaats.nl/a/auto-onderd...-aw11.html
His shed seems to be very organized, so I wouldn't be surprised if he has a set available.
You could also try to source a new assembly via Toyota with these part numbers:
https://www.toyodiy.com/parts/p_E_1985_T..._8103.html
If it's still available it's way cheaper than the Ebay part. Wink
11-14-2021, 10:02 AM
AW11 bumper lights will fit, but the mounting studs are in a different spot, but it is possible to relocate the studs as the housing is exactly the same. I couldnt find any here in Japan for under $300 USD when I was building my car so I used MR2 ones. Also the harness is a little different so you will need to crimp up some adapter wires.
  Kouki to Zenki Levin grill conversion? Mylesmck 6 2,084 02-08-2024 10:30 AM
Last Post: r.ave
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,137 03-05-2023 09:34 PM
  Bash bar for zenki trueno bumper gh0st 3 1,360 02-08-2023 10:50 PM
  Can you convert your 86 back too the original state? gh0st 7 2,730 04-25-2022 04:25 PM
Last Post: gh0st
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,300 09-08-2021 12:48 PM
Last Post: Ryo
