Catch tank oil line size?
01-21-2007, 07:55 PM
I noticed that GReddy offers 2 different tubing sizes. 9mm and 15mm. Which is for the hachi??
http://www.alamomotorsports.com/greddy/g...chcan.html
My evil Red/Black Panda
My current JDM AE86 project
01-21-2007, 11:13 PM
Peter I went to my spare engines and measured it for you :-D
the valve cover outlet diameter is 0.9 cm (9mm)
01-22-2007, 06:36 PM
Thanks Robo.....made the same post on driftworks.co.uk and it seems that 9mm is common for N/A engines, and 15mm is common for Turbo´ed engines.
Seems to agree with your measurement Thumbs up!
  Shim size for AM cams kazi 4 5,414 12-18-2017 05:34 PM
  fuel line hose from the pump Wikizz 4 6,266 10-16-2017 07:11 PM
Last Post: jdm86gtz
Wink Hub size kazi 5 9,995 06-09-2017 10:06 PM
Last Post: kazi
  bubbles in expansion tank? fax0815 5 6,221 04-28-2017 04:57 PM
Last Post: fax0815
  Camshaft sprocket bolt size? harkes 1 4,786 07-03-2015 12:41 PM
Last Post: Dave W
