(Catching up...) OST-083: Salvage operation
07-07-2022, 01:27 AM
[Image: AEU86 AE86 - (Catching up...)  OST-083: ... operation]
While I was able to do a great deal in salvaging this head - this was truly borderline where it should have been welded up and rebuilt. The fact that this was going on a mostly stock engine (California so stock cams), and the client not wanting to spend that kind of money helped me decide*.
cleaned and pressure tested... Huh and tumbled. It is obvious that the challenge here will be cylinder 3
* - What also helped me decide was the fact that the decay was all inside the fire ring of the head gasket. The old head gasket - stuck to the head helped protect the head.
Porting proceeds.... Typical crappy short radius from a smallport head...
and exhaust work....
and a 4 panel showing just how much that chamber improved......
ready for re-assembly
Dan -
07-11-2022, 07:11 PM
Impressive how well that cleaned up!
07-11-2022, 08:32 PM
That before pic looked so gruesome I was expecting a twist to happen somewhere in the middle. But it didn't and great job on reviving this head! Thumbs up!
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,564 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,948 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,370 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,718 06-28-2022 09:17 PM
  (Catching up...) OST-081: STOP... do not touch if you don't know wtf you are doing oldeskewltoy 0 1,623 06-17-2022 09:07 PM
