Centre Propshaft Bearing - How much play is too much ?
10-17-2005, 05:41 PM
Damn,
lots of questions I've been asking today - sorry folks. Whilst my car was up on the ramp on saturday I took a general look under the car to see how it was holding out. I've got a front oil seal dead on the engine that is weeping a bit but nothing too serious. The other thing I checked over was the propshaft. The one on my car is a 2-piece item that has a bearing carrier in the middle that bolts up the the tunnel. If I grab the prop near the bearing carrier there seems to be quite a bit of play (maybe 5mm). This kinda suggests to me that the bearing has collapsed. Next time somebody has there car on a ramp could you see how much play is in yours ? Regards Ian. ![]() |
10-17-2005, 07:22 PM
Don't worry about it.
If you care or it starts flopping around, get a custom 1 piece prop to rid your car of the gay centre bearing. They are cheap. |
10-17-2005, 07:28 PM
Good to know brother william. You always come to the rescue.
10-17-2005, 08:53 PM
Unless you feel any vibration in the tunnel under hard acceleration or at cruising speed divna worry!
Like bro will says when it giives up go for a 1 piece prop (easy to make up) ![]() |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 8,373 |
07-28-2022 10:48 PM Last Post: banpei |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,288 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 7,296 |
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 30,899 |
06-27-2018 11:15 PM Last Post: Ryo |
20v mains & big end bearing | izanagi | 9 | 10,799 |
12-26-2016 12:42 PM Last Post: pack |
