Changing propshaft bearing. Anything I need to know?
04-13-2012, 06:43 PM
Hi guys,
I'm going to be changing the bearing on my propshaft as there's a bit of play in the current one. I've bought a new one from Toyota:
[Image: AEU86 AE86 - Changing propshaft bearing....d to know?]
I'm guessing it's a matter of undoing the four bolts that secure the prop to the bearing. Then there's a nut that's got a crimped edge over it. Am I right in thinking that I simply undo this bolt (is it easy to undo?) and then I can remove the prop from the bearing?
Am I right in thinking put the prop through the bearing, torque up nut then re-fit and that's it?
Also have the rear gearbox oil seal to replace. If I remember correctly, it just comes out by hand as the intermediate shaft from the box holds it in place normally?
Rear gearbox oil seal:
I think I know what I've got to do, but just wanted to check first!
Cheers all! Smile
1985 Sprinter Trueno GT Apex
2013 GT86 Miltek Exhaust, Injen Induction.
04-13-2012, 11:13 PM
recommend you mark all flanges BEFORE you begin, and when re-assembling using the marks to make sure everything goes back in the same place. Re-assembling it in this fashion should not need rebalancing... which can be the need if you don't put the marks back together
Dan -
04-14-2012, 12:12 AM
As above.
Undo the nut with a impact gun and you also need a 2/3 arm puller.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
04-14-2012, 12:56 AM
Hmm, I've already had it off when I took the gearbox off a couple of weeks ago. I've no idea if it was bolted up against the same flanges. I guess the chances are one in four.
Also, I don't have air tools and I don't have a puller. Doesn't sound like I can't get it done at the moment.
04-14-2012, 04:16 AM
The pieces of the driveshaft are supposed to be balanced seperately... but sometimes things will be a bit out of whack 20+ years down the road and not reassembling exactly the same can potentially 'show' those problems.
If a problem wasn't noticed after last time, just mark it this time as a 'just in case' measure.
Andrew
04-15-2012, 02:12 AM
I did my propshaft bearing a couple of weeks ago. You don't need airtools to change it, but I would recommend at least the following:
Vice, Flathead screwdriver, Hammer, Socket wrench, Torque wrench and a Mandrel or a piece of wood.
Do like this:
1. Mark everything up and remove the shaft from the car.
2. Use the Flat head screwdriver and hammer to make the nut round (or roundish) again.
2. Put it in a vice and undo the nut.
3. Hammer out the shaft, using either a mandrel or a piece of wood.
4. Replace the bearing, remember to face it the correct way!
5. Torque up the nut (pref a new nut, but the old one works fine) first to 196Nm then loosen the nut and torque it up to 30Nm.
6. Hammer the nut so it gets deformed into the groove.
7. Install and line it up.
8. Done! Smile
  Exhaust has white smoke coming out and I dont know why... mister86 3 6,362 01-19-2020 12:06 AM
Last Post: Power_uP
  20v mains & big end bearing izanagi 9 12,592 12-26-2016 12:42 PM
Last Post: pack
  Anyone know what this plug does? Super86 3 7,663 08-01-2016 03:57 PM
Last Post: Nakilad
  Changing distributor when carb 4age izanagi 14 19,213 07-04-2016 03:27 PM
Last Post: Uzelac
  Wheel Bearing Temperature Super86 5 8,236 09-29-2014 12:26 AM
Last Post: jondee86
