Check battery light goes ON
09-27-2008, 11:36 PM
Hi folks,
This afternoon my check battery light got on. The check engine light is off, so i think it is not the alternator. The crazy thing is, if i rev it passed 5k the light goes off? Does anyone know what it could be? Did the battery just die? Regards Martin |
09-27-2008, 11:40 PM
Think it's the alternator.. when mine died, the check engine light stayed off too.. that one only comes on when you have serious problems.
09-27-2008, 11:48 PM
try to check all connections, but i think it's the alternator, because at higer revs the alternator JUST works enough to put out the light.
09-28-2008, 12:52 AM
Ok,
Just messured the battery terminals while idle: 12.4V, which is quite low. Reved a bit and got 12.5 - 12.6V which is ways to low, as lead-battery neads at least 13.2V to charge. Any suggestions? Still the alternator I think.... Regrads Martin P.s. took the bat out to charge over night. |
09-28-2008, 01:04 AM
could be the wire. I had that, eventually I switched the plug (that goes into the back of the alternator) to fix the problem
If the wire connects well or doen'st that makes the light go on and off. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
09-28-2008, 01:48 AM
Sounds like your alternator is about to die. The light will come on more and more frequently then it'll finally give out usuall. Get a remanufactured alternator with a lifetime warranty and you won't have to worry about it again. A few people have replaced them with one from a 7mge I think, could be a way to go to gain some extra amperage since you're swapping it out anyway.
-Brandon |
09-28-2008, 09:13 AM
Belt loose ?? Brushes worn ??
Cheers... jondee86 |
09-28-2008, 09:53 AM
robokill Wrote:could be the wire. I had that, eventually I switched the plug (that goes into the back of the alternator) to fix the problem Yeah, but it is strage, that over 5000RPM the light goes off and it's quite systematicly, so I don't thing it is just a bad connector making trouble... |
09-28-2008, 10:30 AM
If you raise the engine speed to the point where the light goes off,
then add some load such as switching the lights on... does the charge warning light come back on ?? Cheers... jondee86 |
09-28-2008, 02:28 PM
Just made a fast check with a fully charged battery: 12.8V with the light still one. Turned on the light, foglight, radio etc. heater... 12.2V. It is definitly the alternator!
Where to get a new one? |
AE86 Battery specs | hachirokuGTV | 9 | 16,846 |
03-13-2020 04:16 PM Last Post: Power_uP |
Engine Check Light at High RPM | Super86 | 8 | 8,738 |
11-03-2014 11:03 AM Last Post: Super86 |
Quick question for those who have relocated their battery.. | Jezza_hr | 10 | 11,105 |
03-06-2014 12:38 AM Last Post: rene |
Jap battery in uk? | phill 92 | 3 | 6,395 |
11-06-2012 11:00 AM Last Post: phill 92 |
battery question | Petros AE86 | 5 | 7,147 |
10-17-2012 08:15 PM Last Post: JGeorge |
