Cig lighter
05-27-2017, 02:56 PM
Cig lighter
Hi guys, should this work on AE86? I have to replace mine as it is rust as hell!
http://www.ebay.co.uk/itm/Vintage-Car-Ci...SwFGNWT0We 1985 AE86 (ハチロク) Levin - Summer time daily driver |
05-27-2017, 09:28 PM
Cig lighter
It should work electrically as it is a generic cigarette lighter. It uses 12 volts and has two only connections, so it should be a straightforward swap. The only question is if it will fit 100%. The diameter of these is the same for the inside, but it could be slightly different on the outside and the same for the mounting points.
I think the chances are higher using a lighter from Toyota from that era. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-27-2017, 09:42 PM
Cig lighter
Thanks Art, I just have to try this... as it is cheap ass, if it wont fit... I will find the toyota one..
05-29-2017, 10:34 AM
Cig lighter
(05-27-2017 09:42 PM)oldskull Wrote: Thanks Art, I just have to try this... as it is cheap ass, if it wont fit... I will find the toyota one..True. For a bargain this cheap you don't have a lot of risk. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
