Clutch release bearing - do you have this part?
06-25-2009, 01:22 PM
Hey,
i'm looking at this (lower) diagram: http://www.toyodiy.com/parts/p_J_1986_TO..._3101.html
.. and i see there is some sort of a hub that goes between the push fork and the bearing. I think i dont have this. I'm pretty sure the bearing goes straight on the shaft from the transmission, and the fork pushes against the bearing directly when cluch is depressed. Do you have this hub?
And also, i dont have the bearing that goes between the clutch an the flywheel - 33311W on the upper diagram. Do you have this folks?
Man im confused.. i didnt have this things before, and the clutch worked okay. Dumb question
06-25-2009, 01:53 PM
Apolan, the 33311W is placed on the flywheel/crankshaft. That's why you don't see it.
And the hub you're talking about is most of the times attached to the bearing. The clutch wouldn't work without the hub.
Best regards
06-25-2009, 01:56 PM
Okay, thank you apardal! I will recheck my bearing, maybe i was just sloppy when inspecting.
06-25-2009, 11:55 PM
apardal Wrote:Apolan, the 33311W is placed on the flywheel/crankshaft. That's why you don't see it.
Best regards
confirm that - just replaced my clutch and thos bearings last week
the release bearing is pressed onto the hub which is connected to the fork with the two clips Wink
06-26-2009, 02:11 AM
Alrighty than! Thumbs up!
  20v mains & big end bearing izanagi 9 10,791 12-26-2016 12:42 PM
Last Post: pack
  How would/have you rebuild your 4age? joaotcgt 6 9,240 07-21-2015 10:40 AM
  How far should I have to push my clutch in dinkers542 4 6,411 11-29-2014 11:18 PM
Last Post: dinkers542
  Wheel Bearing Temperature Super86 5 6,995 09-29-2014 12:26 AM
Last Post: jondee86
  Quick question for those who have relocated their battery.. Jezza_hr 10 11,547 03-06-2014 12:38 AM
Last Post: rene
