Coil Spring Question ??
05-04-2010, 05:33 AM
I have some Tokico 5-way adjustable shocks on my AE86, but just have the stocks springs. I have played around with the adjustments, but most run on 5 (stiffest) setting even for daily drive since it feels the best. - It may be a little harsh at times, but I was thinking this might just be because of the springs. They are just he stock springs.
I was wondering how I should choose springs for the car. I don't care about lowering it, just curious if there is something that would complement the shocks better that was not too expensive. I see a lot of inexpensive D1 springs on ebay. |
05-04-2010, 07:55 AM
Forget ebay D1 springs. Try a set of thicker swaybars, that should do the trick.
05-05-2010, 03:42 AM
NoHachi Wrote:Forget ebay D1 springs. Try a set of thicker swaybars, that should do the trick. I will do sway bar and bushings later in the summer. Right now I was looking at doing springs since I am doing rotors and ball joints. Thought I would dive in further and remove the strut and replace the springs. I think I definitely need a stiffer spring. - Would the D1 be a good spring over the stock springs? They said the are just like Tanabe's: http://cgi.ebay.com/ebaymotors/ws/eBayIS...MEWAX%3AIT Also these D1 say a 1.8" drop, which seems like a lot. Has anyone used these springs? What other adjustments or mods would I have to make if I bought some of these? |
05-06-2010, 03:43 AM
Quick follow up to above post: What adjustments would need to be made, if any, for springs that would drop this much?
05-06-2010, 02:40 PM
juantonwan Wrote:Quick follow up to above post: What adjustments would need to be made, if any, for springs that would drop this much? Traction Brackets at rear and Roll Center Adjusters at front. |
Smallport coil | totta Crolla | 2 | 1,938 |
08-12-2022 11:03 AM Last Post: totta Crolla |
How to test coil with igniter | DJexor | 2 | 8,299 |
03-22-2018 10:01 AM Last Post: Project D |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,804 |
05-04-2015 01:17 PM Last Post: Project D |
clutch pedal return spring | Eifelaner | 2 | 7,469 |
09-06-2013 10:21 AM Last Post: Apsogos |
P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 3,376 |
04-05-2012 04:17 PM Last Post: Dino86 |
