Coil Spring Question ??
05-04-2010, 05:33 AM
I have some Tokico 5-way adjustable shocks on my AE86, but just have the stocks springs. I have played around with the adjustments, but most run on 5 (stiffest) setting even for daily drive since it feels the best. - It may be a little harsh at times, but I was thinking this might just be because of the springs. They are just he stock springs.
I was wondering how I should choose springs for the car. I don't care about lowering it, just curious if there is something that would complement the shocks better that was not too expensive. I see a lot of inexpensive D1 springs on ebay.
05-04-2010, 07:55 AM
Forget ebay D1 springs. Try a set of thicker swaybars, that should do the trick.
05-05-2010, 03:42 AM
NoHachi Wrote:Forget ebay D1 springs. Try a set of thicker swaybars, that should do the trick.
I will do sway bar and bushings later in the summer. Right now I was looking at doing springs since I am doing rotors and ball joints. Thought I would dive in further and remove the strut and replace the springs.
I think I definitely need a stiffer spring. - Would the D1 be a good spring over the stock springs? They said the are just like Tanabe's: http://cgi.ebay.com/ebaymotors/ws/eBayIS...MEWAX%3AIT
Also these D1 say a 1.8" drop, which seems like a lot. Has anyone used these springs?
What other adjustments or mods would I have to make if I bought some of these?
05-06-2010, 03:43 AM
Quick follow up to above post: What adjustments would need to be made, if any, for springs that would drop this much?
05-06-2010, 02:40 PM
juantonwan Wrote:Quick follow up to above post: What adjustments would need to be made, if any, for springs that would drop this much?
Traction Brackets at rear and Roll Center Adjusters at front.
  Smallport coil totta Crolla 2 1,840 08-12-2022 11:03 AM
Last Post: totta Crolla
  How to test coil with igniter DJexor 2 8,118 03-22-2018 10:01 AM
Last Post: Project D
  SOME 4AG valve spring specs oldeskewltoy 5 13,630 05-04-2015 01:17 PM
  clutch pedal return spring Eifelaner 2 7,364 09-06-2013 10:21 AM
Last Post: Apsogos
  P-valve CLOSED --> Stiffer spring will do it :) Dino86 1 3,325 04-05-2012 04:17 PM
Last Post: Dino86
