Corolla GT-Z twin cam 16 (4A-GZE)
10-05-2010, 06:07 PM
Update! Almost done with welding, So far I have almost used a whole 10liter welding gas!
Pictures say more than words so here we go:
[Image: AEU86 AE86 - Corolla GT-Z twin cam 16 (4A-GZE)]
Not very clear in the picture but I managed to fix the left pocket edge as well with the left over from the fender.
To make it look as much as original I decided to stick the fender underneath the carsheet, this way it is as flat as possible. From the inside I can protect the overlay. My working order was:
1. cut away the old fender right in the gully lets say.
2. mark the top center
3. mark the top center of the new fender
4. measure the distance between the inner arch edge and the line where you cut on diffenrent spots
5. copy these measurements to your new fender
6. cut away what you don`t need but leave a strip extra for overlap and incorrect measurements.
7. put new fender overtop and put the marks on top of each other. Check if the front lines up and cut away the rear (this is where your bumper will be attached)
8. check if the inner en new outer wing meets up nice and tack weld it into place
9. now you check how it will look with the bumper attached, nice flow of line? you did your measurements correct and are now ready to finisch it up!
I am not a professional welder and this was my first attempt, maybe there are better ways of doing this but I am satisfied with this, maybe somebody can use this someday..
10-05-2010, 07:36 PM
Gaat goed man . Die wielbogen lijken wel origineel .
Cool Respect!
10-05-2010, 08:13 PM
very nice Thumbs up! Thumbs up!
10-05-2010, 08:18 PM
Thumbs up! welding looks great keep up the good work.
  project "twin cam 16" another AE86... fax0815 11 18,324 11-19-2011 09:05 AM
Last Post: BOOMEX
  Twin-Cames 16 from switzerland movies.... P2 Anonymous 29 30,567 06-29-2010 11:44 PM
Last Post: Anonymous
  Opex: AE85 3a-gze>>3a-gzte in progress opex 24 36,572 01-14-2010 06:09 AM
Last Post: opex
  Mikzu's 4A-GZE project Mikzu IV 22 35,477 11-03-2008 04:11 PM
Last Post: Jousi
  ae86_sr20 drift cam ae86_sr20 32 31,529 01-01-2008 04:23 PM
Last Post: ae86_sr20
