07-29-2016, 04:51 PM
Post: #541
Coool
![]() ![]() 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
02-16-2024, 08:15 PM
(This post was last modified: 02-16-2024 09:41 PM by apardal.)
Post: #542
Hi guys! Been a long while since I last posted something here.
Car is slowly coming back to its stock form with some mishaps in the meantime. Assembled a rebuilt stock engine but something went wrong and 370km in the engine spited out 2 con rods ending up hitting the freeway rails. Car wasn’t too bad, but building another engine took forever. 2 years later, car is back on the road and so far everything is fine. Need to change the crown wheel and pinion to the original one since the 4.77 is whining a lot. Had a nice Blaupunkt Bremen with BT installed which looks great and I’m trying to use the car more often, but either I’m getting too old for this, or the car is infiltrating a lot more gas fumes inside the cabin. It gets to the point where I get headaches. It has been like this for a long time, but maybe a little worse since the last time I remember. Do you have any ideas on where it may come from? |
02-16-2024, 10:48 PM
Post: #543
The 3-door AE86 is notorious for sucking in exhaust fumes from the rear if it's not sealed properly. There are two things to check:
1) Check the rubber seal of the hatch 2) the tail light gaskets may have gotten old, become brittle and now don't seal properly You can probably use generic rubber seal replacements. The gaskets are available on Flos.ie and can be found here. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 56,959 |
11-23-2018 10:13 PM Last Post: sylwekgtir |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 16,022 |
RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 32,389 |
Shell make over a coat of paint | williep12 | 4 | 7,351 |
02-01-2010 03:52 PM Last Post: Kid Karola |
Repair/ Body | whitepoint | 6 | 8,611 |
03-12-2008 09:21 PM Last Post: whitepoint |
