Crank pulley without harmonic damper
05-07-2014, 07:31 AM
The rubber in my old pulley is on the way out so I am looking for a new one. I want it with a 36-1 trigger Wheel - currently I have one welded on the stock pulley which is balanced with the engine.
My concern is that aftermarket pulleys do not have a damper and I don't really know how well balanced they are.
So far I have been looking at the T3 option + trigger wheel:
https://technotoytuning.com/toyota/16v4a...k-pulley-0
https://technotoytuning.com/toyota/16v4a...gger-wheel
And TTV underdrive pulley:
http://ttvracing.com/product/toyota-4a-g...1-trigger/
I like that the TTV is one piece and not just a trigger Wheel held on with two screws but it is slightly more expensive than the T3 option.
Any thoughts on this? Any other options I should look at?
[Image: AEU86 AE86 - Crank pulley without harmonic damper]
05-07-2014, 07:42 AM
the solution for me was a new oem two row, machined to remove the outer section.
my trigger wheel is mounted to the front
Dan -
05-07-2014, 10:17 AM
Why did you choose the OEM pulley Dan?
05-07-2014, 11:16 AM
OEM is so far the only damped one I found so far, apart from custom jobs which are very expensive.
Sent from my Nexus 4 using Tapatalk
05-07-2014, 02:28 PM
Yes but do we NEED the damper? I have no idea what expect concerning life time!
05-07-2014, 03:52 PM (This post was last modified: 05-07-2014 03:54 PM by Bean.)
(05-07-2014 02:28 PM)Jan Pedersen Wrote:  Yes but do we NEED the damper? I have no idea what expect concerning life time!
I'd like to say no but unfortunately we do need it. with the strain from the belts you'd shorten the life of the engine quite a bit.
Have a look at other high revving engines in race use - even they fit harmonic dampers despite the fact they open-up/rebuild their engines once a season or more.
I got a non damped one too (part of a kit) but I won't fit it unless I can find a way to convert to being damped. Unfortunately I have no clue how one would do that and still keep it safe.
05-07-2014, 04:06 PM
Thats my biggest reason and fear for the aftermarket pulleys,they are withouth the damper that is needed Sad
05-07-2014, 04:11 PM
here some opinions from both side - make your own.
http://www.aeu86.org/forum/showthread.php?tid=8155
05-07-2014, 06:15 PM
At the time... it was after a chat with Arnie Loyning... I've forgotten the specifics... but it had to do with the early crank not being a true full counter weight type, and it was susceptible to breaking @ 8500 rpm (+ or -) without a dampened pulley.
Not sure what your budget is...... it is quite a bit cheaper these days($392 vs $501) then back in 2008
http://www.bhjdynamics.com/index.php?mai...cts_id=158
I paid $275.00 for mine, and then I sent it off to Jackson Autosport to get modified... they modified it, an old distributor, and built the wiring harness for the FJO managment.
Dan -
05-07-2014, 07:45 PM
(05-07-2014 06:15 PM)oldeskewltoy Wrote:  [Image: AEU86 AE86 - Crank pulley without harmonic damper]
must resist Angel
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 19,666 08-16-2018 01:36 AM
  crank 6 bolt flywheel DJexor 5 8,957 12-05-2016 08:21 AM
Last Post: d3nso
  4ac crank on 4age! Ghetto 7 11,056 12-05-2014 10:42 PM
Last Post: Uzelac
  Crank seal TheGerman 8 11,783 04-12-2014 09:36 AM
Last Post: Apsogos
  4AGE 16V crank weights fax0815 6 10,548 02-09-2013 10:08 PM
