Cusco adjustable top mounts on Konis problem
07-02-2008, 12:23 AM
Hi guys
I know this was mentioned before but was not able to find the thread. I just wanted to fit some Cusco top mounts onto my Koni dampers but the top screw is too big. What was the solution to this?? Thanks for your help. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
07-02-2008, 12:43 AM
had that problem......
just find normal nut's (not long ones) but with the locking bit or use loctite ![]() with the T3 camber plates, i used smaller nuts on that picture. but some time after i machined the camber plates a bit so that the locking bit actually touches the thread. |
07-02-2008, 01:07 AM
Did you just machine the existing nuts down?
Isn't it having some kind of play this way? Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
07-02-2008, 10:55 AM
i did the same, without the bit going inside the camberplate, never had any problems with play at all
![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
07-02-2008, 01:04 PM
it's not the camber plate that was machined (or the nut) it's a spacer that the T3 camber plates have between the shock absorber and the camber plate.
never had any problems with play with both solutions |
07-02-2008, 04:23 PM
@speed inc
In verbindung mit den konis brauchst eigene muttern, ich schau dir zuhause mal nach, vielleicht habe ich noch die teilenummern bzw. die abmessungen von Tein. |
07-02-2008, 04:28 PM
M12x1,25
07-03-2008, 10:52 AM
Vielen Dank Ash
I see if Cusco has something matching. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
Red top in the ae86 | gh0st | 25 | 11,458 |
08-08-2022 08:43 PM Last Post: gh0st |
Replacing Top Windscreen Moulding | chrisae86 | 2 | 2,165 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 21,267 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,370 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,644 |
