Cylinder head - TORX bolts - what size?
08-10-2007, 03:09 PM
Today i've starting ripping my engine appart and i've removed the camshafts to discover torx bolts. So since i dont have the apropriate wrench/part for it. So im wondering what size it is? so i can go buy one. And do i need a beefy one, are the forces big? I dont waste my money on parts that will break naturally Big Grin
thanks!
08-10-2007, 03:47 PM
10mm 12-Point Deep Socket, like this: [Image: AEU86 AE86 - Cylinder head - TORX bolts - what size?] or or SST 09205-16011 :wink:
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
08-10-2007, 03:55 PM
Much thanks S.K.! Thumbs up! Off to hardware store i am Smile
08-10-2007, 09:57 PM
It is incredible just how hard it is to find that piece of equipment here. I have been to all of the biggest hardware stores in slovenia and nothing. Luckily there was a shop who has theese. So if such parts are ahrd to find, how can i get my hands on even more specialised tools. How do you people get by? where do you get your "special tools"? (mostly engine-related)
08-10-2007, 10:17 PM
Most of the shops that sells aftermarket car parts have these special tools here in Denmark. Did you receive the centercap ? Smile
http://s141.photobucket.com/albums/r69/larszylauv/
08-10-2007, 10:46 PM
hahaha our aftermarket car parts shops only have lexus style lights, alot of plastic, neon lights and similar waste material.. Confused
And yes, forgot to say thanks, i have recieved the centercap. So.. thanks Thumbs up!
08-11-2007, 07:21 PM
That socket is not special in any way.. a lot of ratchet kits come with 12-point sockets..especially cheaper ones since the 12-points have a tendency of killing bolts sooner than proper 6-sided sockets. You dont even need a deep socket to get to the headbolts, just use an extension bar. I will add that a set of deep sockets is a nice thing to have.
08-11-2007, 08:04 PM
well maybe not deep, but they definatelly have to be narrow to fit between the head castings. I have a VEEERY old set of 12-points, from my father/grandfather.. they are very robust and strong. But they just dont make them that way anymore.. cheap sets are good only for "hobby-use", and the good ones cost alot of money.. but the 12-points are just very hard to find here, let alone some really "special" tools.
08-15-2007, 05:56 PM
Apolan Wrote:well maybe not deep, but they definatelly have to be narrow to fit between the head castings. I have a VEEERY old set of 12-points, from my father/grandfather.. they are very robust and strong. But they just dont make them that way anymore.. cheap sets are good only for "hobby-use", and the good ones cost alot of money.. but the 12-points are just very hard to find here, let alone some really "special" tools.
Actually... with superior tool companies smaller does NOT mean poorer. Companies like Snap-on, MAC, and a few others have superior engineering. For instance... I have gearless ratchets... they work on a cam principle! That means even 3 degrees of arc and I can tighten/loosen bolts!!!
Dan -
08-15-2007, 06:39 PM
I know it doesnt, i just said that you cant get decent tools for the normal price anymore (here). My grandfather bought this set of 12-points back in the days for normal money - and that was probably the only set availible back then here - but it is much much better than any set i've seen in our stores now (excluding the hi-priced hi-performance tools).
  4AGE cylinder head plug removal Ivan141 5 3,024 09-30-2023 09:47 PM
  Head bolts: You decide..... oldeskewltoy 8 11,465 11-11-2020 06:33 PM
  Shim size for AM cams kazi 4 5,868 12-18-2017 05:34 PM
  Brake advice - master cylinder mannix20vt 12 15,985 08-21-2017 03:21 PM
Last Post: Project D
Wink Hub size kazi 5 10,590 06-09-2017 10:06 PM
Last Post: kazi
