DIY: 4age Valve Stem Seals.
08-09-2007, 10:46 PM
Ivan141 Wrote:I get some smoke at startup, none visible when driving.. but it will leave small clouds when accelerating from a standstill full-throttle or on downshifts. Sounds like you've got bad stem seals. Not too far off how mine was acting. Oil pressure could be just the gauge/sensor changing resistance a little. Maybe try cleaning the contact to the pressure sender? Andrew |
10-18-2007, 07:49 AM
have changed the valve stems due to your help guys. jus wanted to say thanx
![]() http://www.heerlijklimburg.nl |
11-12-2007, 12:58 PM
Does anyone know how to purchase this item? snap on sites only sell locally!
Best regards |
11-19-2007, 06:30 AM
apardal Wrote:Does anyone know how to purchase this item? snap on sites only sell locally! Go to their website and see if they have your country listed, if they do it should lead to a website/portal for your country. Once their you can either purchase directly, or you can email them and find out WHO the local snapon 'agent' is to get a hold of them to purchase it. Andrew |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 1,052 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,619 |
HKS valve springs | totta Crolla | 3 | 2,460 |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 18,920 |
Valve clearance | leon205gti | 7 | 8,958 |
