Defi Tachometer on Carbies
03-30-2010, 11:33 AM
Is that posible to use the ignition coil for the rpm signal?
Thanks 1982 Toyota Corolla KE70 1992 Subaru Legacy BF5T |
04-06-2010, 10:39 AM
All old toyota suse coil negative wire for the tacho.
04-06-2010, 06:26 PM
Yes I know that but since defi tachometer uses the control unit since it only shows the ecu signal from ecu for wiring, i was wonderind about the coil?
If not MSD 6A has a rpm signal output, does it do the job? 1982 Toyota Corolla KE70 1992 Subaru Legacy BF5T |
04-13-2010, 09:55 AM
dollykean Wrote:Yes I know that but since defi tachometer .... Didnt mention this in the first post. |
Slow tachometer problem. LHD AE86. | Arima-kun | 2 | 5,539 |
06-22-2014 11:17 PM Last Post: Arima-kun |
Tachometer wire colour | Jezza_hr | 8 | 15,658 |
10-13-2013 03:52 PM Last Post: parrot |
problem with defi rpm gauge | fax0815 | 14 | 28,668 |
06-13-2012 10:41 AM Last Post: fax0815 |
Help! Lost tachometer, water t. gauge, alternator wont charg | Saber | 9 | 14,087 |
05-21-2012 08:06 PM Last Post: Saber |
tachometer | nikos_trd | 2 | 4,235 |
09-26-2009 06:06 PM Last Post: Ivan141 |
