Defi Tachometer on Carbies
03-30-2010, 11:33 AM
Is that posible to use the ignition coil for the rpm signal?
Thanks
1982 Toyota Corolla KE70
1992 Subaru Legacy BF5T
04-06-2010, 10:39 AM
All old toyota suse coil negative wire for the tacho.
http://www.skynet.ie/~eireae86
04-06-2010, 06:26 PM
Yes I know that but since defi tachometer uses the control unit since it only shows the ecu signal from ecu for wiring, i was wonderind about the coil?
If not MSD 6A has a rpm signal output, does it do the job?
04-13-2010, 09:55 AM
dollykean Wrote:Yes I know that but since defi tachometer ....
Didnt mention this in the first post.
  Slow tachometer problem. LHD AE86. Arima-kun 2 4,834 06-22-2014 11:17 PM
Last Post: Arima-kun
  Tachometer wire colour Jezza_hr 8 13,800 10-13-2013 03:52 PM
Last Post: parrot
  problem with defi rpm gauge fax0815 14 25,872 06-13-2012 10:41 AM
Last Post: fax0815
  Help! Lost tachometer, water t. gauge, alternator wont charg Saber 9 12,425 05-21-2012 08:06 PM
Last Post: Saber
  tachometer nikos_trd 2 3,688 09-26-2009 06:06 PM
