What size of tires with 14' Konig Rewind ?
10-24-2006, 10:08 PM
Hi !
I have 190/60/14 tires on my Rewind , and when I turn , the front tires rubs on the body Confused
What size is the best ?
Thank you very much !
10-24-2006, 10:11 PM
185/60 on mine
10-24-2006, 10:19 PM
The US guys recommend 185/60 to avoid rubbing. That being said, it is not the best choice in terms of grip, although it should still handle pretty well on 185 with good suspension.
10-25-2006, 09:07 AM
Make 6mm steel spacers using worn-out rear brake discs (they are 8mm thick). With up to 6mm you still can use original wheel studs.
10-25-2006, 05:27 PM
oldskull Wrote:185/60 on mine
Rubs on mine, but mine was lowered a bit more than yours. Wink
Still got to remove the plastic thing in the fender though. Undecided
[Image: AEU86 AE86 - What size of tires with 14' Konig Rewind ?]
  Winter tires Ryo 7 5,700 01-30-2020 05:33 AM
Last Post: oldeskewltoy
  Shim size for AM cams kazi 4 5,443 12-18-2017 05:34 PM
Wink Hub size kazi 5 10,069 06-09-2017 10:06 PM
Last Post: kazi
  Camshaft sprocket bolt size? harkes 1 4,807 07-03-2015 12:41 PM
Last Post: Dave W
  (Video) Tips to choose a good set of tires Homem Bomba 1 4,331 07-22-2013 04:59 PM
Last Post: Homem Bomba
