Different cam duration
02-09-2008, 12:47 PM
Hi guys
Is there anyone who can tell me, why somebody mount 2 cams with different duration? Ex. 304 in and 300 ex? Confused
02-09-2008, 10:48 PM
Shamelessly stolen from Club4ag.....
http://www.club4ag.com/faq%20and%20tech_..._story.htm
Quote:An interesting aspect of cam duration is the use of a dual pattern or
different duration cams for the exhaust and intake. When used correctly,
a different exhaust duration from the intake can broaden the torque range,
but generally speaking they will not deliver as much peak torque as can be
found with matched cams in a narrower RPM range.
This is not all bad because it is still torque that wins races. Typically you
will see the exhaust cam one step lower in duration than the intake to
broaden the torque range, but I have not seen anything that says you can
not do it the other way around.
There ya go Smile
Cheers... jondee86
02-10-2008, 11:05 AM
Thanks Thumbs up!
  Cam Cap Bolt Snapped!! Alex170984 1 3,838 06-08-2018 01:17 PM
  HKS 260 8.0 Cam Card d3nso 5 7,119 02-14-2018 08:29 PM
  Using a different diff in an AE86 megabob 6 8,631 02-17-2015 03:37 PM
Last Post: megabob
  suspicious TRD cam ;) fax0815 6 9,962 02-02-2013 09:44 PM
  Interesting 20v cam cover mod banpei 3 9,071 05-31-2012 02:44 PM
Last Post: Kid Karola
