Digital Cluster temp and fuel wont turn on
09-17-2010, 09:30 PM
ok so yesterday i spent the whole day splicng and wat not but when i got the end of of the results my tach, temp, and fuel were not turning on....
re did the wiring twice and got better results as i kept messing wit it but the tach temp and fuel did not turn on at all could it be the led lights broke?? or maybe a fuse of some sort broke?? any help would be appreciated
here are some pics of it done
[Image: AEU86 AE86 - Digital Cluster temp and fuel wont turn on]
09-19-2010, 03:30 PM
Is there current going through the fuel and temperature wiring???try to check using a multi-meter first..i don't think there is the usage of the fuse..I did had problem on the tacho wiring due to the lack of 1 extra wire on my distributor the rpm read.
10-21-2010, 01:37 PM
http://www.aeu86.org/viewtopic/digital-d...1/start=75
same problem with you buddy.
did you solve it?
  Digital Dash evfan42 190 261,986 05-03-2024 06:44 PM
  EUDM gauge cluster banpei 22 4,531 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 1,269 06-23-2023 09:11 AM
Last Post: r.ave
  Digital speedometer on stock dashboard FanIsHere 0 1,420 11-09-2022 01:36 PM
Last Post: FanIsHere
  Trueno Digital dash kph to mph Bojack 3 7,023 11-21-2018 12:27 AM
Last Post: kazi
