Digital Cluster temp and fuel wont turn on
09-17-2010, 09:30 PM
ok so yesterday i spent the whole day splicng and wat not but when i got the end of of the results my tach, temp, and fuel were not turning on....
re did the wiring twice and got better results as i kept messing wit it but the tach temp and fuel did not turn on at all could it be the led lights broke?? or maybe a fuse of some sort broke?? any help would be appreciated here are some pics of it done |
09-19-2010, 03:30 PM
Is there current going through the fuel and temperature wiring???try to check using a multi-meter first..i don't think there is the usage of the fuse..I did had problem on the tacho wiring due to the lack of 1 extra wire on my distributor the rpm read.
10-21-2010, 01:37 PM
http://www.aeu86.org/viewtopic/digital-d...1/start=75
same problem with you buddy. did you solve it? |
Digital Dash | evfan42 | 190 | 261,999 |
05-03-2024 06:44 PM Last Post: banpei |
EUDM gauge cluster | banpei | 22 | 4,540 |
EUDM cluster revelations | banpei | 1 | 1,269 |
06-23-2023 09:11 AM Last Post: r.ave |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,421 |
Trueno Digital dash kph to mph | Bojack | 3 | 7,024 |
11-21-2018 12:27 AM Last Post: kazi |
