Distributor RedTop vs. Bluetop
12-28-2007, 11:18 AM
Did anybody put distributor from RedTop on BlueTop engine.
They are little different, but I think it can work with no trouble. The main question is does it fit mechanicaly, does driven gear fit.. etc. ? Pic down is the BlueTop one (on my car), and upper pic is RedTop one (from AE92 GTi). Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
12-28-2007, 11:57 AM
I'm not completely sure, but I think they send different types of signals to the ecu, making them incompatible. Something to do with the number of teeth on the signal gear.
12-28-2007, 12:18 PM
Ivan141 Wrote:I'm not completely sure, but I think they send different types of signals to the ecu, making them incompatible. Something to do with the number of teeth on the signal gear. Manual doesn't make any difference between them about signal. Connector is different but the signal to ECU seems the same, G-, G and Ne signal. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
12-28-2007, 03:46 PM
There are two redtops - Bigport and Smallport.
Bigport redtop uses essentially the same signals as Bluetop - 24 teeth NE wheel and 4 teeth G wheel (with one sensor). Smallport on the other hand uses 24 teeth NE wheel and 1 tooth G wheel with two sensors - G1 and G2. AE86 GTS '84 Red Top |
12-28-2007, 06:18 PM
2 Bad Dog: Tnx ...
..so I'm in trouble Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
12-28-2007, 09:02 PM
Yep, the bigport redtop distributor works just fine on a bluetop. I've got one on my car and just swapped the plugs to fit it on the engine.
Do note, however, that you must use the correct cap for the distributor - an AE86 cap doesn't fit at all and AE82 one fits upside down. Even with what I believed was the correct cap (leads exit at a V-angle, two on each side), the timing was 180 degrees off from the numbers marked on the cap and I had to change the order of the leads to make the engine run. I may have had a wrong type of rotor, though. And like Bad Dog said, the smallport distributor with the triangle-shaped connector is completely different and not useful at all unless you also use a smallport ECU (among other things). |
12-29-2007, 01:23 PM
zmeshin , squirt that biatch, trow out the distr... use crank sensor with ms and some bosch coil pack out of peugeot 205 gti or even citroen zx 1.8 liters .... (free to grab @ junkyard )
12-29-2007, 02:08 PM
Rio_Cyber Wrote:zmeshin , squirt that biatch, trow out the distr... use crank sensor with ms and some bosch coil pack out of peugeot 205 gti or even citroen zx 1.8 liters .... (free to grab @ junkyard ) I'm not streetracer .. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
12-29-2007, 02:13 PM
no , u are pedestrian now
12-29-2007, 02:27 PM
Rio_Cyber Wrote:no , u are pedestrian now You're right about that... Come on, dig up some distributor from that shed of Yoyota parts you got there ... I got RedTop distributor in perfect condition... lets exchange Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 9,152 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,964 |
16v distributor hole plug | harkes | 8 | 9,412 |
Bluetop on turbo | leon205gti | 7 | 7,822 |
09-20-2016 09:17 PM Last Post: leon205gti |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 33,468 |
08-21-2016 04:51 PM Last Post: ray |
