Doubt about TRD springs height
08-22-2008, 09:11 AM
hachirokuGTV Wrote:I had to cut half a coil to get the rear to set down level with the front. Running TRD front and rear with short stroke setup. Kinda wish I had just found a spring that sits the car lower than a trd rather than cut it. (they don't sit to good on the spring seat when you start cutting them)
B-Tune/ Swift springs
[Image: AEU86 AE86 - Doubt about TRD springs height]
08-22-2008, 11:27 PM
Do you know how I can get hold of a pair? Need 5kg or 5.5kg max i think.
08-23-2008, 01:46 PM
hachirokuGTV Wrote:Do you know how I can get hold of a pair? Need 5kg or 5.5kg max i think.
Ask SYM from Passracing, he provided me with Swift springs before. I thought you can get them in 6.0 or 4.5.
09-03-2008, 05:20 AM
Both TRD & Swift (afaik) both won't put the fender/wheel arches even. The reason being the arches AREN'T even on the body/car height wise.
Andrew
  HKS valve springs totta Crolla 3 2,163 05-25-2022 10:24 PM
  Springs from other vehicles?? FanIsHere 16 14,423 05-17-2016 09:12 AM
Last Post: FanIsHere
  3rd door support gas springs (stay) - worn out max_ae86 5 6,135 09-01-2013 03:20 PM
Last Post: Jezza_hr
  Gear end , drive pinion height filh 5 11,133 06-27-2013 12:29 AM
Last Post: filh
  Kaaz width doubt, OEM is out of car T_AE86 3 5,130 04-13-2013 12:05 AM
Last Post: T_AE86
