Doubt about TRD springs height
08-22-2008, 09:11 AM
hachirokuGTV Wrote:I had to cut half a coil to get the rear to set down level with the front. Running TRD front and rear with short stroke setup. Kinda wish I had just found a spring that sits the car lower than a trd rather than cut it. (they don't sit to good on the spring seat when you start cutting them) B-Tune/ Swift springs 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
08-22-2008, 11:27 PM
DJexor Wrote:hachirokuGTV Wrote:I had to cut half a coil to get the rear to set down level with the front. Running TRD front and rear with short stroke setup. Kinda wish I had just found a spring that sits the car lower than a trd rather than cut it. (they don't sit to good on the spring seat when you start cutting them) Do you know how I can get hold of a pair? Need 5kg or 5.5kg max i think. |
08-23-2008, 01:46 PM
hachirokuGTV Wrote:Do you know how I can get hold of a pair? Need 5kg or 5.5kg max i think. Ask SYM from Passracing, he provided me with Swift springs before. I thought you can get them in 6.0 or 4.5. 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
09-03-2008, 05:20 AM
Both TRD & Swift (afaik) both won't put the fender/wheel arches even. The reason being the arches AREN'T even on the body/car height wise.
Andrew |
HKS valve springs | totta Crolla | 3 | 2,173 |
Springs from other vehicles?? | FanIsHere | 16 | 14,434 |
05-17-2016 09:12 AM Last Post: FanIsHere |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,138 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
Gear end , drive pinion height | filh | 5 | 11,140 |
06-27-2013 12:29 AM Last Post: filh |
Kaaz width doubt, OEM is out of car | T_AE86 | 3 | 5,138 |
04-13-2013 12:05 AM Last Post: T_AE86 |
