High-beam warning lamp
07-20-2023, 05:06 PM
Hello everybody,
I'm experiencing some issues with my headlights; on full beam the blue warning lamp is really dim, barely detectable by the human eye.
Has anyone experience of this?
The earth is good, the other warning lights (door open, fuel) are much brighter.
When it's lit, it's only getting 6volts which appears to be correct to as per the wiring diagram, ie. I series with the low beam so 6v + 6v = 12v. Should it be a different rated bulb? 6v as opposed to 12?
Any guidance appreciated
07-20-2023, 08:13 PM
Don't worry, all sorted now
07-20-2023, 11:22 PM
What was the cause then? Dumb question
[Image: AEU86 AE86 - High-beam warning lamp]
07-21-2023, 12:35 AM
I had mixed up the terminals at one of the headlights, effectively putting the main and dip filaments in series and taking 6v from between them to feed the warning light
07-21-2023, 07:44 AM
(07-21-2023 12:35 AM)Mylesmck Wrote:  I had mixed up the terminals at one of the headlights, effectively putting the main and dip filaments in series and taking 6v from between them to feed the warning light
Thanks!
That explains it indeed.
  Engine stress at high speeds gh0st 6 2,875 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 23,484 12-31-2020 06:39 AM
Last Post: chenfon
  Bonnet lamp pod for AE86 Dino86 0 3,077 01-04-2018 11:08 PM
Last Post: Dino86
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 36,539 08-21-2016 04:51 PM
Last Post: ray
  Peculiar headlight issue - main beam Jezza_hr 3 6,069 10-04-2015 09:25 PM
Last Post: Jezza_hr
