need info distributor 4A_C and 4AGE
07-09-2007, 07:35 AM
got a 4AGE head fitted to a 4AC block all done(all 4AGE)PArts
got it drop in my old 4A-C(carb) this is the new setup 4Age with weber carb ..i need to connect the distributor.. how do i connect this to my old 4AC setup |
07-09-2007, 09:35 AM
http://www.rollaclub.com/board/index.php...opic=11302
4AGE ignition depends on 4AGE ECU. Better use different ignition management (some people even use static ignition advance). IMHO go MjLj (mappable, http://www.picasso.org/) or some distributor with mechanical advance + driving gear from 4AGE one (for example - 4K one). You can use 4-ping HEI igniter to drive the ignition coil - this is simple and cheap setup. |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 6,474 |
| 16v distributor hole plug | harkes | 8 | 11,386 |
| Changing distributor when carb 4age | izanagi | 14 | 19,254 |
| 4age 16v 1st and 2nd generation cams and not only difference | Apsogos | 3 | 8,636 |
09-16-2013 08:24 AM Last Post: Apsogos |
| Injector sizes info | ZaX | 19 | 40,590 |
