Electric fan size
09-11-2008, 10:48 PM
Electric fan size
Hi
I have plans fitting an electrical fan on my radiator in my 86. I have bought the thermostat and only lack the fan it self. My question is: How heigh is the stock radiator? I'm not close to mine at the moment so I can't measure it. I can choose between 10, 12 and 14 inch fans. Have anyone mounted an electrical fan? What is you experience? What setup did you make? Cheers Martin AE86 - 4AGE - 1984 My project - http://www.aeu86.org/viewtopic/another-d...on/t/13190 |
09-12-2008, 12:24 AM
Electric fan size
AFAIK it is 12" high.
I'm about to buy one also. Best regards |
09-22-2008, 04:20 AM
Electric fan size
I suggest getting symmetrical fans with an even amount of fins. From what I have researched this makes for the best flow.
09-22-2008, 07:34 AM
Electric fan size
Hi
I not quite sure I follow you. Do you mean two on one side or one on each side? I guess one on each side would give a very high air flow. /Martin AE86 - 4AGE - 1984 My project - http://www.aeu86.org/viewtopic/another-d...on/t/13190 |
10-14-2008, 05:59 AM
Electric fan size
Just make sure that your flan is slim enough and that there are an even amount of fins to make sure that you have the best flow.
Electric windows | totta Crolla | 0 | 252 |
03-18-2025 11:00 PM Last Post: totta Crolla |
Shim size for AM cams | kazi | 4 | 5,409 |
Hub size | kazi | 5 | 9,980 |
Camshaft sprocket bolt size? | harkes | 1 | 4,771 |
Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 9,818 |
