Engine rebuild project! Share your ideas...
09-12-2012, 10:44 PM
Also, if you can sell that brand new block (Keep the head
![]() ![]() 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
09-12-2012, 11:17 PM
Rascal21 Wrote:Also, if you can sell that brand new block (Keep the head You just descriped my build ![]() On another note, considering you intend to drift with this car and the fact you can't import an engine from abroad. What about a engine swap from another car which is available (miata, rotary, ca18, etc)? AE86 ex-daily |
09-13-2012, 10:37 AM
Keep the block and sell the head
![]() Half decent heads are plentiful but when was the last time a brand new block became available ? Ideally you want to build the engine from a full donor engine as everything you need is there already. If you can find a smallport crank and rods then you can buy new smallport pistons to fit the new block from Toyota at reasonable cost. Smallport pistons are the best stock 16v pistons available, last time I enquired on price they were £72 each + rings. An analogue brain in a digital World |
09-13-2012, 10:41 AM
totta Crolla Wrote:Keep the block and sell the head Or get custom ones like me incl. pins and ring for ~700$ the set, that's 100 more than what you'd pay for OEM AE86 ex-daily |
09-13-2012, 11:22 AM
Has to be block with oil squirters imo.
3 rib is a bit on the weak side (Someone tried remedying that on my car by screwing plates along each side of the block, it didn`t help ![]() Either keep all of it to build basically an immaculate stock ae86 engine (Only one in the world hehe) but if you want reliable performance even with a lot of tuning an ae92 kouki, ae101 or ae111 block is needed. Bean: Well how about that! How much HP u getting at the wheels? 150? 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,151 |
04-25-2022 04:25 PM Last Post: gh0st |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 10,105 |
Rear Differential rebuild | chenfon | 10 | 9,837 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 10,539 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,572 |
