Engine rebuild project! Share your ideas...
09-12-2012, 10:44 PM
Also, if you can sell that brand new block (Keep the head Wink ) you have a bit more to play with, save some more money and do full-tune Bigport or smallport head w/ae101 throttles and standalone ECU w/dizzy-less ignition & COPS (Coil on plugs)+ as well as Toda pistons, lightweight pulleys along with full engine balance, oughta put you around the upper top 20 of most serious street-engine builds on most 86 forums Wink
1x TA60 82' Sedan 2T 8V
09-12-2012, 11:17 PM
Rascal21 Wrote:Also, if you can sell that brand new block (Keep the head Wink ) you have a bit more to play with, save some more money and do full-tune Bigport or smallport head w/ae101 throttles and standalone ECU w/dizzy-less ignition & COPS (Coil on plugs)+ as well as Toda pistons, lightweight pulleys along with full engine balance, oughta put you around the upper top 20 of most serious street-engine builds on most 86 forums Wink
You just descriped my build Smile
On another note, considering you intend to drift with this car and the fact you can't import an engine from abroad. What about a engine swap from another car which is available (miata, rotary, ca18, etc)?
09-13-2012, 10:37 AM
Keep the block and sell the head Smile
Half decent heads are plentiful but when was the last time a brand
new block became available ?
Ideally you want to build the engine from a full donor engine as
everything you need is there already.
If you can find a smallport crank and rods then you can buy new smallport
pistons to fit the new block from Toyota at reasonable cost.
Smallport pistons are the best stock 16v pistons available, last time I
enquired on price they were £72 each + rings.
09-13-2012, 10:41 AM
totta Crolla Wrote:Keep the block and sell the head Smile
Or get custom ones like me incl. pins and ring for ~700$ the set, that's 100 more than what you'd pay for OEM
09-13-2012, 11:22 AM
Has to be block with oil squirters imo.
3 rib is a bit on the weak side (Someone tried remedying that on my car by screwing plates along each side of the block, it didn`t help Tongue )
Either keep all of it to build basically an immaculate stock ae86 engine (Only one in the world hehe) but if you want reliable performance even with a lot of tuning an ae92 kouki, ae101 or ae111 block is needed.
Bean: Well how about that! How much HP u getting at the wheels? 150?
  Can you convert your 86 back too the original state? gh0st 7 3,085 04-25-2022 04:25 PM
Last Post: gh0st
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 9,784 04-19-2021 10:08 PM
Last Post: Hanzo
  Rear Differential rebuild chenfon 10 9,670 11-20-2020 12:18 AM
Last Post: totta Crolla
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 10,402 01-17-2020 08:04 PM
Last Post: Project D
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,346 08-19-2018 12:08 PM
Last Post: AlexKTM
