Engine starts/revs but no idle
11-16-2021, 02:30 PM
RE: Engine starts/revs but no idle
Check the vacuum hose going to the fuel reg. Do you see a change in fuel pressure. When disconnected, should be at 38 PSI and at idle it should be about 29 PSI.
Double check the cold start injector for leakage, when the engine is up to temp. Dave W |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,434 |
exhaust odor/idle MOT issue | Ryo | 7 | 7,260 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 17,196 |
08-16-2018 01:36 AM Last Post: Bean |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,156 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
Silver top low idle | AlexFourTwenty | 7 | 10,138 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
