Eric's KE70 08/10 Longchamps!
12-08-2008, 05:59 PM
Post: #111
Offcourse i will show them
![]() Are you going to buy a KE70 in Malaysia ![]() |
12-08-2008, 06:56 PM
Post: #112
If everything going smooth, I will buy an KE70 in Malaysia with 4AGE ready for my brother there. But this mean when I go to Malaysia I could drive it too
![]() 1985 AE86 (ハチロク) Levin - Summer time daily driver |
12-08-2008, 07:10 PM
Post: #113
ah, you are not going to import it to the Netherlands?
03-25-2009, 11:46 PM
Post: #114
Long time no update..
Got the ae86 front crossmember in, all powdercoated and all. engine went in for a testfit, fits like a glove! ![]() Then i started working on the pedals since the KE has a cable clutch fitted and it need to be rebuild to hydraulic. KE firewall ![]() TE firewall ![]() almost the same but it needs a little bit of modification. Redrill a couple of holes and when that is done i will be able to fit the TE pedals into the KE. KE pedals, cable clutch ![]() TE pedals, hydraulic clutch ![]() TE has two pieces, the clutch pedal is mounted seperately. Then i started working on the axle's.. ![]() Rusted small one is std. KE axle, yellow one ( ![]() Notice the difference in diff size and rear brake size. There also is a light difference in lengt of propshaft, the TE axle is a little shorter due to the length of the diff housing. Today i was fighting to get the T3 tracktion brackets on the TE axle, the middle hole willnot fit ![]() ![]() ![]() After that it is off to get the roll cage in! |
04-04-2009, 07:40 PM
Post: #115
Finally: it is rolling again!
full lock, ![]() iall adjustable T3 stuff, ![]() ![]() i rolled it 4 meters from were it was sitting for the past 6 months ![]() ![]() rear underneath, ![]() |
04-04-2009, 10:12 PM
Post: #116
Got some lock there!
04-13-2009, 08:41 PM
Post: #117
Today i made holes for the master clutch cilinder:
![]() ![]() Tomorrow i will make new holes for the brake booster etc. ![]() And i have to find me a new clutch cilinder. I dont want to put back the old rusty thing i have now. I bought a new one from an ae86 but it has different mounting points. |
04-13-2009, 08:49 PM
Post: #118
take it apart, refurbish it (buy new seals), spray it, put it back.
Finished ![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
04-13-2009, 09:08 PM
Post: #119
No
![]() I want all new parts! |
04-13-2009, 09:26 PM
Post: #120
what is that rusty thing in your last pics then?
Eric O'Sullivan's AE2000 | BenR | 39 | 51,697 |
11-15-2006 12:01 AM Last Post: Mux213 |
