Exhaust fumes in cabin (Hatch seal problem!)
05-27-2015, 06:20 PM
(05-26-2015 09:08 PM)roman Wrote: Hey I just had similar problems, annoying me for ages so I ended up stripping out the entire interior to find out where it was coming from. Well, last weekend I took most of the interior trim in the rear apart but I couldn't seem to find anything untill I closed the hatch and looked from the inside. As you can see on the picture there is light shining through in between the hatch and the trunk seal. On both the left and right hand side from the lock, the seal isn't even touching the hatch, the opening is quite big and this must be the reason why it is pulling fumes in to the cabin. I didn't have any time left to check if the hatch is adjustable in height (like the hood of the car). Did anyone else have this problem? If so, how did you fix it? The seal is in really good condition so that does not need replacing. ![]() |
05-27-2015, 07:09 PM
There are rubber stoppers under the hatchlid, but I dont know if they are adjustable. Worst case you could fit some foamrubber strips on the hatchlid where you need the added insulation, and you'll probably hardly notice it at all.
05-27-2015, 07:31 PM
(05-27-2015 07:09 PM)Ivan141 Wrote: There are rubber stoppers under the hatchlid, but I dont know if they are adjustable. Worst case you could fit some foamrubber strips on the hatchlid where you need the added insulation, and you'll probably hardly notice it at all. I thought about the rubber stoppers as well but can't check at the moment... Only concern is that the lock would be the limiting factor in that case. foamrubber is a good idea ![]() |
05-27-2015, 10:25 PM
Nice catch!
The lock should be adjustable by unscrewing the two bolts and shifting the lock to another position. Dunno about how much it already has been adjusted... 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-07-2015, 11:52 PM
Usual way of getting doors to close on the seals is to bend
the door a little ![]() up towel under the side that touches first, and then push firmly on the other edge. Start gently, checking the sealing after each push, and slowly push harder until you obtain the desired result. The hatch is a large and not very stiff door. It probably closed once with something under one edge to give it a bit of a twist. You just need to twist it back. Cheers... jondee86 |
06-09-2015, 09:00 PM
(06-07-2015 11:52 PM)jondee86 Wrote: Usual way of getting doors to close on the seals is to bend Thanks Jondee! While I was figuring about how to tackle the problem I did indeed find the edge to which the hatchseal sticks was bend a little bit low. Still in perfect condition though but it could be better. Now it's almost entirely closed. May need a little more adjusting. The fume smell is a lot better ![]() |
11-13-2015, 01:20 PM
With my 20V i'm getting tired of high rpms and exhaust fumes.....
Bahhhhhh i like the smell but gets deeply into my clothes.... |
Problem exhaust drone: Solution 1/4 wave, or Helmholtz resonator? | oldeskewltoy | 5 | 10,259 |
05-17-2017 11:36 PM Last Post: Bean |
Crank seal | TheGerman | 8 | 10,935 |
04-12-2014 09:36 AM Last Post: Apsogos |
Annoying sound (Ae92 hatch gti) | Apsogos | 2 | 4,517 |
01-02-2013 12:13 PM Last Post: Apsogos |
4agZe problem solved - 99% IC problem | Okami | 41 | 36,814 |
07-12-2012 04:49 PM Last Post: Okami |
Hatch seatbelts - question | cannabolic | 1 | 3,706 |
07-28-2011 09:43 PM Last Post: cannabolic |
