F20C in AE86
01-24-2014, 07:27 AM
F20C in AE86
About to start this swap in RHD.
I dont want to space the subframe, and dont mind totally remaking the subframe. Is that an option? Keen to hear opinions and advice from those that have done it... Cheers! |
01-25-2014, 12:24 AM
F20C in AE86
I've only seen a completely custom subframe/cradle on an ae86 once, and it happens to be a f20c swap. Here's the link:
http://club4ag.com/forums/viewtopic.php?...0&start=80 |
01-25-2014, 12:41 AM
F20C in AE86
Awesome! Thanks for the link, Ill email him and see if he wants to sell / make one for me.
02-21-2014, 09:46 AM
F20C in AE86
In goes the S2000 (F20C) engine, out goes the trans tunnel! A couple more... Cross member modification for the sump. |
02-21-2014, 08:18 PM
F20C in AE86
Good to see you went with a good solution and not the one from the link.
02-21-2014, 10:39 PM
F20C in AE86
Yeah you just need to redrill a couple of holes for the arms and the geometry is corrected. All arms are adjustable and the total spacer height to clear the bonnet is 20mm, so thats ok.
04-18-2014, 01:31 AM
F20C in AE86
Nearly done. |
04-18-2014, 07:09 PM
F20C in AE86
It's coming along nicely.
I wish I would have checked back on this earlier. I'm also glad you didn't go with the sub frame in the link because the steering rack brackets don't even look close to road worthy, and there's only one metal tube connecting both sides of the x member (it's a drag car so I doubt he minds). I only posted the link to give you ideas since you were curious about a custom sub frame. |
04-19-2014, 11:02 AM
F20C in AE86
Yeah its getting there, not much left to do, will be an interesting drive with 6 speed close ratio box and 4.9 diff revving to 9k
04-28-2014, 10:57 AM
F20C in AE86
wow nice build
AE86 F20C swap - Radiator issue | mad.matt | 3 | 5,897 |
02-07-2018 05:14 PM Last Post: mad.matt |
AE86 with F20C project | 4000GT | 3 | 4,988 |
11-10-2013 02:52 AM Last Post: 4000GT |
f20c vs 3sge | Petros AE86 | 7 | 13,713 |
02-26-2012 12:29 PM Last Post: roiz86 |
F20C / F22C --> AE86 wiring inquiry | dacoupe | 4 | 15,760 |
08-27-2008 05:36 AM Last Post: F0Bman |
